The Flightradar 24 interesting traffic thread
Burner
Closest Airfield: LIMB
Has thanked: 86 times
Been thanked: 697 times
Re: The Flightradar 24 interesting traffic thread
Unread post by Burner »
Snitch wrote: Fri Jun 21, 2024 1:05 am Notice King Air Z-WSG is flying Lanseria to Harare at only 17,000ft
She often flies at only between 16,000 and 17,000ft
This is because she is a medical transport and often has to fly low to keep cabin pressures high for patients onboard
A good mate of mine flies for Halsted, will ask him why they're flying lower. They do medevacs out of Zim, so I can understand flying lower from Harare to Lanseria with the patient, but this is a return flight which I'm 99% sure would be an empty positioning flight.
These users thanked the author Burner for the post:
Snitch
Snitch
Closest Airfield: Unknown
Has thanked: 173 times
Been thanked: 521 times
Unread post by Snitch »
Segg wrote: Fri Jun 21, 2024 10:42 am
Sounds more like an INOP yaw damper, without the dual strakes on the empennage you're limited to FL170 in a BE20 :)
Could be
Its been INOP a while then
African Flyer
Has thanked: 244 times
Been thanked: 93 times
Unread post by African Flyer »
Julian Assange
Positive rate! :D
Snitch
British Airways A350 G-XWBD as BAW42F on her way back to London after sitting on the ground in Cape Town for 6 days with some sort of technical problem
Balloothebear
Stall training
Closest Airfield: FALE
Has thanked: 13 times
Been thanked: 36 times
Unread post by Balloothebear »
Interesting visitor …
Was up in the wee hours of the morning as well ..
Twenty years from now you will be more disappointed by the things that you didn’t do than by the ones you did do.
Explore. Dream. Discover. Mark Twain.
grjplanes
Has thanked: 7 times
Been thanked: 39 times
Unread post by grjplanes »
A VistaJet Global 7500 en-route CPT-MAD have turned around over southern Namibia and seems to be diverting into Upington, looks like been on a much lower altitude for quite a bit on the way to UTN.
GLF4
Has thanked: 61 times
Been thanked: 191 times
Unread post by GLF4 »
grjplanes wrote: Wed Jul 03, 2024 12:15 pm A VistaJet Global 7500 en-route CPT-MAD have turned around over southern Namibia and seems to be diverting into Upington, looks like been on a much lower altitude for quite a bit on the way to UTN.
Now dumping fuel. It's the one that broke down on the 17th June, think a hydraulic leak?
African Flyer
GLF4 wrote: Wed Jul 03, 2024 12:55 pm
Positive rate! :D
RVSM
Engine Cranking
Has thanked: 11 times
Been thanked: 19 times
Unread post by RVSM »
Rumour has it the pax didn’t clear customs and immigration at Cape Town and had to turn around… I’m sure there are some very red faces at the FBO.
Snitch
RVSM wrote: Thu Jul 04, 2024 4:23 pm Rumour has it the pax didn’t clear customs and immigration at Cape Town and had to turn around… I’m sure there are some very red faces at the FBO.
Sounds strange
The only thing one does at OR Tambo on a commercial flight leaving SA is flash the sleepy official the outside of your passport when you leave.
Nothing is looked at or done
Is it different in CPT or for private flight pax ?
African Flyer
Air India 🛩🇮🇳
Positive rate! :D
b-rad
Steep Turn Right
Closest Airfield: FAPM
Has thanked: 8 times
Been thanked: 17 times
Unread post by b-rad »
7500 can’t dump fuel.
Armchair
Been thanked: 9 times
Unread post by Armchair »
I see that Qantas QFA63 from Sydney to Johannesburg is diverting to Melbourne.
GLF4
b-rad wrote: Tue Jul 09, 2024 12:00 pm
Didn't realise it couldn't dump fuel. Expensive exercise burning off fuel.
Snitch
Quite a fast drone. 176 KTS :lol:
ITs actually air Tractor AT-502B ZS-XAS
