The Flightradar 24 interesting traffic thread
- Incipient Spin
- Closest Airfield: Cape Town Airport
- Has thanked: 123 times
- Been thanked: 145 times
Re: The Flightradar 24 interesting traffic thread
Poor GE125 was about to start descent into Cape Town and is now heading back to Johannesburg...some passengers probably won't be happy about the 3 hour flight to nowhere!
Clear prop!
- Flaps set for Take off
- Closest Airfield: JNB
- Has thanked: 52 times
- Been thanked: 20 times
New Air Zimbabwe heading to JNB, AZW467. Hex 00406E which is a new one. Descending shortly. Do they have any new ones? Z- ???
I wonder if it might be the E145 Z-WPU with a recoded transponder as it was still using the hex from Aerolitoral XA-RLI on its last few flights.
- 10000 and still climbing
- Closest Airfield: Unknown
- Has thanked: 166 times
- Been thanked: 463 times
Pakistan Air Force Glex J-758 at Waterkloof
- These users thanked the author Snitch for the post:
- Aquila
- Has thanked: 54 times
- Been thanked: 169 times
REG is definitely Z-WPU, got a pic on arrival. I suspect it's ex N214MA, XA-RLI.
- These users thanked the author GLF4 for the post:
- TGRK
- Closest Airfield: FAGC
- Has thanked: 203 times
- Been thanked: 85 times
Russians
Positive rate!
T7-FIS doing calibration flights at Durban today
T7-FIS calibrated East London today, then moved on to PE
- Tree Tousand
- Closest Airfield: FAVV
- Has thanked: 8 times
- Been thanked: 355 times
This seems like quite a short test flight...
Dirk de Vos
- Tree Tousand
Does anyone know whether this aircraft is leaving the country as well or is it perhaps being prepared to join one of the other local airlines?
Dirk de Vos
- Frequent AvComer
- Closest Airfield: FAGM
- Has thanked: 418 times
- Been thanked: 109 times
It's a 400 so probably on its way out.
One of the ex-Comair 400's now flies in the "lovely" region of East Africa (Somalia, Sudan etc) with Dallo out of Nairobi for example.
Going to Fanjet Express Kenya as 5Y-FQC
- ddevos
- Preflighting
- Has thanked: 1 time
- Been thanked: 0
I followed a plane yesterday and at Bella-Bella it just disappeared ????? see flightradar below
It was tracked via MLAT, not ADSB.Rotor Wing wrote: ↑Sat Aug 17, 2024 10:07 pm I followed a plane yesterday and at Bella-Bella it just disappeared ????? see flightradar below
MLAT required multiple ground stations to track it to estimate its position
It went out of range of enough stations
Interesting visitor 🛩
Positive rate!
