The Flightradar 24 interesting traffic thread
Springbok006
Power off Glide
Has thanked: 4 times
Been thanked: 29 times
Re: The Flightradar 24 interesting traffic thread
Unread post by Springbok006 »
Aquila wrote: Sun Sep 08, 2024 8:56 am
Springbok006 wrote: Sat Sep 07, 2024 9:59 pm
Aquila wrote: Sat Sep 07, 2024 1:10 pm
I highly doubt that the flight crew will forget to update the flight details in their FMS. Its very much part of flight initialization SOP and if you did put in the wrong flight details ATC would notify you that you are broadcasting incorrect info. I reckon its got to do with FR24...
Hello Aquila! Just to point out, incorrect programming of the FMS has nothing to do with ATC.
Hi @Springbok006 , I have never flown an Embraer but on the Airbus we definitely have to put in the correct callsign in the INIT page on the FMS. If not, ATC will tell you that the callsign your aircraft is broadcasting does not match your flight plan. The FCOM states that: "The FMS sends the number to the ATC system". So I'm pretty sure it it has to do with ATC... :wink:
Aha! Learnt something thank you!
Snitch
Closest Airfield: Unknown
Has thanked: 171 times
Been thanked: 506 times
Unread post by Snitch »
ZS-RSA finally made it home from Singapore today around 12:30Z
Has thanked: 1376 times
Been thanked: 951 times
Unread post by richard C »
Snitch wrote: Sun Sep 08, 2024 10:36 pm ZS-RSA finally made it home from Singapore today around 12:30Z
Zuma was right - should have bought that B777 after all :twisted:
Grant all equity and dignity
Has thanked: 1936 times
Been thanked: 2169 times
richard C wrote: Mon Sep 09, 2024 8:44 am
I was roasted by my previous employer for referring to Inkwazi as the Nkandla Express. Has anything changed other than the occupants :twisted:
Paul Sabatier
GLF4
Has thanked: 57 times
Been thanked: 187 times
Unread post by GLF4 »
Apparently Jakarta airspace was closed for the Papal Mass? Did this have something to do with the return to Singapore? Maybe NOTAM weren't read?
TGRK
Closest Airfield: JNB
Has thanked: 62 times
Been thanked: 24 times
Unread post by TGRK »
ddevos wrote: Sat Sep 07, 2024 5:18 pm @TGRK, I just noticed something, there are two CemAir flights that are active at the moment, being 5Z610 (flight 5Z514) and KEM451 (flight 5Z451). Yet, when I search for CemAir flights, FR24 says there is only one active flight, being flight number 5Z514. Any idea why this would be?
Most of KEM fleet are old rattlers without full ADS-B so they don't ping a callsign from the plane. FR just fudges crappy scheduling data over the top and the resulting shitshow is what you see, You really need a raw 1090Mhz mode-s feed to see what's actually going, eg. adsbexchange, but unfortunately the coverage in SA is poor on their network, Sadly there isn't a "don't show me fudged scheduling data, only show me raw mode-s" in the settings so you're stuck it !
African Flyer
Has thanked: 228 times
Been thanked: 88 times
Unread post by African Flyer »
Airlink's new bird?
Positive rate! :D
GLF4
Yip, their 4th E175.
These users thanked the author GLF4 for the post:
African Flyer
Snitch
Embraer KC390 PT-ZNG doing some circuits at Waterkloof ahead of AAD 2024
African Flyer
Qantas A380 ✈ making a comeback 🇿🇦
Positive rate! :D
African Flyer
TAAG just received their first A220-300
Positive rate! :D
ddevos
Closest Airfield: FAVV
Has thanked: 9 times
Been thanked: 374 times
Unread post by ddevos »
African Flyer wrote: Mon Sep 30, 2024 3:31 pm Qantas A380 ✈ making a comeback 🇿🇦
That obviously means there was enough of an increase in demand for seats. But, one has to wonder what the SAA flights' passenger numbers on average per flight look like...
These users thanked the author ddevos for the post:
African Flyer
Dirk de Vos
African Flyer
ddevos wrote: Mon Sep 30, 2024 3:54 pm
True 💯
Positive rate! :D
AussieFlyBoy
Priming
Closest Airfield: Archerfield Brisbane
Been thanked: 12 times
Unread post by AussieFlyBoy »
It’s not a comeback. Qantas never operated A380s on this route previously. 747s until their demise, and then 787s until this week.
https://www.facebook.com/share/1F9ZeHez ... tid=WC7FNe
African Flyer
AussieFlyBoy wrote: Mon Sep 30, 2024 9:56 pm
My mistake. Thanks for the correction
Positive rate! :D
