The Flightradar 24 interesting traffic thread
African Flyer
Has thanked: 228 times
Been thanked: 88 times
Re: The Flightradar 24 interesting traffic thread
Unread post by African Flyer »
European Cargo A346 had its first flight since February and its compatriot has been here since March
Positive rate! :D
ddevos
Closest Airfield: FAVV
Has thanked: 9 times
Been thanked: 374 times
Unread post by ddevos »
Looks like this Cherokee swallowed a large rocket, saw ZS-JZS, another Cherokee, doing 260kts as well, with a C172, ZS-KCZ doing 210kts too, all at about the same altitude...
Dirk de Vos
TGRK
Closest Airfield: JNB
Has thanked: 62 times
Been thanked: 24 times
Unread post by TGRK »
ddevos wrote: Tue Oct 01, 2024 8:48 pm Looks like this Cherokee swallowed a large rocket, saw ZS-JZS, another Cherokee, doing 260kts as well, with a C172, ZS-KCZ doing 210kts too, all at about the same altitude...
They are MLAT. Barely any coverage in South Afruca as nobody feeds to the tracking site so you'll see all sorts of fake cr@p like this.
Snitch
Closest Airfield: Unknown
Has thanked: 171 times
Been thanked: 506 times
Unread post by Snitch »
Star Air Cargo ZS-TGG B737-300SF had a pressurization failure out of Cape Town last night and had to return.
Snitch
ZS-ZWG is now in Safair colours from Comair/BA after heavy maintenance in Equador.
She did 2 post maintenance flights as N202TS and should ferry back to SA soon
More info :
viewtopic.php?p=2339210#p2339210
Burner
Closest Airfield: LIMB
Has thanked: 86 times
Been thanked: 694 times
Unread post by Burner »
Snitch wrote: Tue Oct 08, 2024 3:23 pm ZS-ZWG is now in Safair colours from Comair/BA after heavy maintenance in Equador.
More info :
For those following Steve and Bob aka speedtapefilms, I see they're doing the ferry.
African Flyer
Air France back in CPT
Positive rate! :D
Zimfly
Forgot to remove the chocks!
Has thanked: 1 time
Been thanked: 6 times
Unread post by Zimfly »
ddevos wrote: Mon Sep 30, 2024 3:54 pm
African Flyer wrote: Mon Sep 30, 2024 3:31 pm Qantas A380 ✈ making a comeback 🇿🇦
That obviously means there was enough of an increase in demand for seats. But, one has to wonder what the SAA flights' passenger numbers on average per flight look like...
One of my workmates has just been to Aussie to visit family, out 3 weeks ago, return yesterday. Went SAA. Full loads both ways. The crew on the way there indicated to him that they woulld be increasing the frequency soon from 3x to 5x a week as they had "new" aircraft coming.
Des Lyle
"Sic itur ad astra - thus one goes to the stars"
Snitch
ZS-ZWG on her way home to SA as N202TS
Now in Recife Brazil
Joker11
Rolling from unmanned
Closest Airfield: EDDF
Has thanked: 77 times
Been thanked: 54 times
Unread post by Joker11 »
Zimfly wrote: Wed Oct 09, 2024 12:03 pm
Another clapped-out A340-300 with an outdated cabin?
In the battle between aeroplanes and the ground. The ground has yet to lose.
Aviation would be great, if it wouldn't be for passengers.
GLF4
Has thanked: 57 times
Been thanked: 187 times
Unread post by GLF4 »
Joker11 wrote: Wed Oct 09, 2024 1:01 pm
Will obviously be ZS-SXD A343 which had a test flight about a month or two ago.
ddevos
Snitch wrote: Wed Oct 09, 2024 12:59 pm ZS-ZWG on her way home to SA as N202TS
Somehow something isn't adding up: after seeing that ZS-ZWG is on its way to South Africa, I started watching its progress every now and then. Delta Flight 200 was some distance behind it, both at 41000ft, but even though the 737 was cruising more than 50 knots (ground speed) slower than the A350, the A350 never managed to catch up with the 737 during the four and a half hours that I have been watching them. I assumed that the 737 was flying a lot slower to save fuel on such a long trip. As they moved in over South Africa, the A350 started getting a bit closer, but it still didn't catch up. Why would this be? Both aircraft have been tracked via ADS-B, so I don't get it. The 737 has just touched down at ORT. I hope TGRK can shed some light on this...
Dirk de Vos
Snitch
ddevos wrote: Wed Oct 09, 2024 7:10 pm 0.1
Watching on a zoomed out FR24 earth like map blurs your perspective about how far apart aircraft actually are
I zoomed in as much as i could with the 2 still visible on 1 screen while they where over the Atlantic about 4 hours out from JHB and measured with a tape measure the screen distance between them.
I then used this measurement against the scale provided by FR24 to get their approximate distance apart.
I then looked at the ground speed difference and divided the distance apart by the ground speed difference.
This showed it would take about 4,3hours for Delta to catch up with OMD
But there was only 4 hours to go to JHB and even less till speed restrictions kick in , so it would never catch it.
They looked real close when zoomed out, but the earth is huge and the distance was deceptive.
The little aircraft symbols we watch at average zoom levels for cruiseing flights are many many times larger than the aircraft itself
African Flyer
New Challenger on the block
Positive rate! :D
Segg
Has thanked: 424 times
Been thanked: 112 times
Unread post by Segg »
African Flyer wrote: Thu Oct 10, 2024 6:10 pm New Challenger on the block
Hmmm soon to be based in Russia I assume? :D
