The Flightradar 24 interesting traffic thread
MrT
FREDA checks
Closest Airfield: CPT
Been thanked: 1 time
Re: FlightRadar24
Unread post by MrT »
From FR 23:00 tonight:
Also heard that a certain MD87 that was held in Canada returned to a neighbouring Kingdom over the past weekend and is now in Jhb.
GLF4
Has thanked: 74 times
Been thanked: 213 times
Re: FlightRadar24
Unread post by GLF4 »
That MD87 being 3DC-SWZ of course :)
Jetblast
Returning to aircraft
Has thanked: 2 times
Been thanked: 9 times
Re: FlightRadar24
Unread post by Jetblast »
How do you know of your aircraft is ADS-B enabled. I'm flying a brand new PC12 and for the life of me don't know if it has ADS-B. All indications on planespotters show it has a hex code the works. But nothing shows up on flight radar
I take life with a grain of salt, a wedge of lime and a shot of Tequila!
Aquila
Closest Airfield: VHHH or FACT
Has thanked: 35 times
Been thanked: 56 times
Re: FlightRadar24
Unread post by Aquila »
Jetblast wrote:How do you know of your aircraft is ADS-B enabled. I'm flying a brand new PC12 and for the life of me don't know if it has ADS-B. All indications on planespotters show it has a hex code the works. But nothing shows up on flight radar
Hi Jetblast, I assume you're flying a NG then which is usually equipped with a Mode S transponder. You will most likely be able to see the aircraft in areas where MLAT coverage are provided... I have seen PC12/47 and 47E's on FR24 in MLAT areas but then again there are also other PC12's that are equipped with ADS-B transponders which are visible in normal ADS-B receiver coverage areas. So basically it depends on what your aircraft is fitted with but as I said the NG's mostly have Mode S transponders...
Raccoon jet driver...
See Horizons!
Snitch
Closest Airfield: Unknown
Has thanked: 177 times
Been thanked: 531 times
Re: FlightRadar24
Unread post by Snitch »
All Mode S transponders have a hex address assigned to them for identification.
If ADS-B equipment were fitted it would be listed on the aircraft equipment list.
Dont think many of any PC-12 have ADS-B yet.
Some of the very new ones are sold with "ADS-B ready" transponders. These have the ports to connect to the optional ADS-B equipment if fitted aboard.
Being mode S your PC-12 may get its position fixed by the new M-LAT capability from Flightradar24 if 4 stations see the aircraft at the same time.
Any receiving station would also get your all your aircraft info from Mode S (Registarion, height, speed ect), but wont know its position
Bianca Albesco
Engine Still Cranking
Re: FlightRadar24
Unread post by Bianca Albesco »
This aircraft is arriving sometime on Friday the 23rd of May at Lanseria and should be departing again around the 24th or 26th for Nairobi. It is going to be back here at FALA around the 28th and leaving again the 29th or 30th.
It is the FAA's Gulfstream that has the interesting registration "N1".
Jetblast
Re: FlightRadar24
Thanks for the replies guys.
Snitch
Re: FlightRadar24
Bianca Albesco wrote:This aircraft is arriving sometime on Friday the 23rd of May at Lanseria and should be departing again around the 24th or 26th for Nairobi. It is going to be back here at FALA around the 28th and leaving again the 29th or 30th.
Intereting.
Due to a glitch on Flightradar24 and some not too well tuned transponders we often see aircraft pop up as N1.
So when she pops up for real most will probably just think its a bad transponder again. :lol: :lol:
HAAN
Closest Airfield: OMDB
Has thanked: 21 times
Been thanked: 98 times
Re: FlightRadar24
Unread post by HAAN »
Wonder why HAAB is not online to see all the Ethiopian operations into Addis.
See South Sudan/Juba is now online.
ppakotze
Closest Airfield: Fly from Morningstar
Been thanked: 19 times
Re: FlightRadar24
Unread post by ppakotze »
Hello Jetblast
Which transponder do you have in your PC12? I have seen the Garmin GTX330 in some. These are mode S, with a software upgrade possible to do mode S with extended squitter. The extended squitter then could broadcast your position which flight radar can pick up. BUT, your transponder then needs wiring from an onboard GPS to provide it with the location information. This would probably not be done already. Doing this on a certified aircraft is not going to be cheap. Plenty of NTCA flying around with mode S transponders with ES showing their location on FR24.
Pieter
Great Dane
Closest Airfield: FAWK
Has thanked: 5 times
Been thanked: 2 times
Re: FlightRadar24
Unread post by Great Dane »
Bianca Albesco wrote:It is the FAA's Gulfstream that has the interesting registration "N1".
Going to be good to finally see it, thanks for the heads-up :smt023
Any clarification on this, Friday is 22nd, 23rd is Saturday. At least if it is this year :wink:
Bianca Albesco
Re: FlightRadar24
Great Dane wrote:Any clarification on this, Friday is 22nd, 23rd is Saturday. At least if it is this year :wink:
Sorry. My information is a bit sketchy. It could be Friday or Saturday. I wonder what it is going to be doing here?
Aquila
Re: FlightRadar24
ppakotze wrote:Hello Jetblast
Pieter
Hi Pieter, I think Jetblast may be flying a PC12NG which has the Honeywell Apex integrated flight deck and that usually has the Honeywell KXP-2290D Mode S transponder fitted. So they usually only show up on FR24 in MLAT coverage areas. Regarding the GTX330, I have flown a PC12 that has a GTN750/650 setup combined with the GTX330 transponder and it displays on FR24 in ADS-B coverage areas...
See Horizons!
Jetblast
Re: FlightRadar24
Hi Aquilla.
Thats correct. Honeywell it is. I think the 12 you are talkimg about might be NYM. Seen it on FR24 frequently
Aquila
Re: FlightRadar24
Jetblast wrote:Hi Aquilla.
That's the one...
See Horizons!
