light sports aircraft running cost
South African Bat Hawk has been designed and developed by Micro Aviation South Africa primarily for surveillance and is the most affordable light sport aircraft on the market.
EtienneFly007
Mags Dead Cut
Closest Airfield: Secunda
Unread post by EtienneFly007 »
Hello
Can I get some information regarding the cost of ownership on one of these light sports aircraft, Bat Hawk, bantam, or similar?
Insurance?
MPI? How regular does the aircraft need to go for MPI?
Is it Yearly?
Or After so many flying hours?
Enjin services?
Same questions?
if I only fly 5 to 10 hrs a year? Does the checks still have to be done annually?
The cost involved in doing those checks...
I have read something about the NPL licence needs to be renewed?
Cost on the NPL renewal every year?
Thank you
Kind regards
Etienne du Plessis
My Hanger - Topflite Cessna 182, UMX - E-flite Carbon Cub SS, and alot of other aircrafts...
AEROMODELING : The art of turning precision-cut and glued balsa wood and foam into toothpicks and confetti.
trevair
Mags On
Closest Airfield: FAPM
Been thanked: 1 time
Re: light sports aircraft running cost
Unread post by trevair »
Hi Etienne
Go for a Jabiru 2 seater 120ul
We use one in our flight school here in Durbs
MPI every year or 100 hours,never more than R2000. 50 hour service R1500 Even if you only fly 5 hours per year it will still need an MPI
All airies need to fly regularly or you will pick up problems so 5 hours per year not enough
LSA flight test with us would be minimum 2 hours at R1100 per hour dual
PM me if you need more info
Trevor Cato Ridge Aviation Centre
These users thanked the author trevair for the post:
befonoy
Steve
Closest Airfield: Wings Park
Has thanked: 17 times
Been thanked: 119 times
Unread post by Steve »
Just note that it is an "Annual Inspection" and NOT an "MPI"....the MPI is every 100 hours or 12 month, whichever sooner.....
The "annual inspection" is every 12 months - irrespective of hours flown...
Steve Onions
EtienneFly007
Mags Dead Cut
So basically I will need to do both, Mpi and annual inspection?
I will never fly 100 hrs or more in a year, max wil be maybe about 36-50... Fuel cost will keep me grounded as I have a strict budget per month.... But fly I want to, and will !!!
ñ Jabiru is awesome aircrafts, but they are a little to expensive to buy. I am looking at the Bathawk, or similar...
Thank you
Etienne
Micro Aviation
Fuelling up
Closest Airfield: Bat Hawk City
Unread post by Micro Aviation »
Dear Etienne,
Please send me an email to info@bathawk.co.za for more comprehensive info on the Bat Hawk.You will not regret your decision to go with a CAMit powered Bat Hawk. They are simple and reliable with no expensive service bulletins every few weeks.
Kind Regards,
Terry
befonoy
Closest Airfield: London City Airport
Has thanked: 2 times
Unread post by befonoy »
trevair wrote: Mon Mar 23, 2015 3:38 pm Hi Etienne
Thanks for this information. I like your advice.
Return to “Bat Hawk”
