Shielded plugs
The Scheibe Falke is a German touring motor glider
FlyFalke
Closest Airfield: Potch
Has thanked: 5 times
Been thanked: 6 times
Shielded plugs
Unread post by FlyFalke »
Looking for the shielded plugs used by Limbach on the 1700 engine. Anybody that would be able to help with a set of plugs. I could change the the newer automotive mag wire set but as the old is working well I would rather try and source the shielded plugs?
Peter Bailey
Closest Airfield: Springs
Been thanked: 16 times
Re: Shielded plugs
Unread post by Peter Bailey »
Try a web site called Club plug. they cost about $ 7.00 each . bring in via UPS . will be here by friday . good luck.
So much to do , so little time !
StemmeS12 ZT GZG
FALKE sf25 ZU ELL
FlyFalke
Re: Shielded plugs
Thanks Peter. I will use them if I can not source any locally.
Return to “Scheibe Falke”
