Manufacture date
checkride
Been thanked: 1 time
Manufacture date
Unread post by checkride »
Gents,
Do engines manufactured 2011 have all the new mods by default or must these be done separately .
Has thanked: 61 times
Been thanked: 922 times
Re: Manufacture date
Unread post by heisan »
checkride wrote:Gents,
Modifications are introduced as the engines are manufactured by serial number. You can view the list of modifications by serial number at the back of the overhaul manual.
Return to “Jabiru Engines”
