Cessna T210N ZS-MPA
HJK
Closest Airfield: FAKT
Cessna T210N ZS-MPA
Unread post by HJK » Thu Aug 20, 2015 2:07 pm
I though to share our recent upgrade to ZS-MPA. She is a T210 with a Turbo Plus Intercooler system. Due to recent engine trouble and being unable to source the problem we opted for a complete engine change :roll: . We are now fitting the Atlantic Aero STC with the Continental IO-550-P Engine and the Hartzell Scimitar Propeller :mrgreen: .
HJK
Re: Cessna T210N ZS-MPA
Unread post by HJK » Thu Aug 20, 2015 8:44 pm
HJK
Unread post by HJK » Thu Aug 20, 2015 8:47 pm
C Africa
Closest Airfield: Wonderboom
Been liked: 101 times
Unread post by C Africa » Mon Aug 24, 2015 7:20 am
Maybe we can start a club? I have one too.
You're going to love it. Just don't think you're ever going to get your investment back if you try to sell it.
For some reason, no-one understands exactly what you did to the plane, and even experienced sales people seem a but dumbfounded.
C
HJK
Unread post by HJK » Mon Aug 24, 2015 9:53 am
You are unfortunately right.
However there is not much if any aeroplane that can replace the 210 for under 3bar. That is why decided to do the conversion and we don't plan to part with it in the foreseeable future.
Here is some pics of the progress thus far: (Cant wait to go and fly it :P )
HJK
Unread post by HJK » Mon Aug 24, 2015 9:59 am
Progress:
HJK
Unread post by HJK » Tue Sep 29, 2015 11:28 am
So the progress is typical aviation: Hurry up and wait............. :roll: 2 Month project dragging past 8 months :shock: At least the first test flights done and the engine is performing ever so well, now just to finish the touch up paint work and sort the avionic snags and we are back in the air!! [-o<
HJK
Unread post by HJK » Wed Oct 14, 2015 11:00 am
Finally :!: We are done! Aircraft is performing well. We have done 20 hours thus far and you can hardly notice the difference between the turbo and the normally aspirated engines. We have done flights up to FL105 and the performance is on par with the T210 but using a little less fuel. A big thank you to Helifix Wonderboom (Henty & Jaco), Century Avionics (Eddie & Shane), and Flash of Coloring (Danie) for all their help and assistance! =D> We are truly enjoying the new lease on life on ZS-MPA.
HJK
Unread post by HJK » Wed Oct 14, 2015 11:03 am
Oh yes.... she also weighs 200lbs less! :mrgreen:
nelis
Forgot to remove the chocks!
Closest Airfield: FATA
Unread post by nelis » Wed Oct 14, 2015 9:29 pm
She's beautiful. Enjoy. I went again for the factory new TSIO 520 R two years ago and am very happy with it. My experience was greatly enhanced by the GAMI injectors and flying lean of peak. Cape Town to jhb in 4 hrs and 200 l, family of 4 and the wife packing. I just cannot find a machine to replace it. Regards nelis
C Africa
Unread post by C Africa » Fri Oct 16, 2015 2:18 pm
As mentioned before, I have the same conversion on mine, and the trick is to run it lean of peak. As much as 20lb's per hour lighter on fuel than the old 520 turbo.
And yes, I also find that it cruises at the same speed as the old Turbo used to, even though I run her on economical settings, not near the power peak.
When you approach your destination and you turn the fuel from lean to rich of peak, you can feel the jump in the plane as it gains the extra power!
Mine has just over 70 hours on now.
C
HJK
Unread post by HJK » Tue Feb 21, 2017 10:22 am
A recent flight in ZS-MPA 8)
HJK
Unread post by HJK » Thu May 18, 2017 10:00 am
Nampo 2017
PilotPaultjie
Mags Dead Cut
Unread post by PilotPaultjie » Mon May 29, 2017 10:12 am
What beautiful photos from Nampo. I'm in love with the 210 again. :smt007 Am so missing flying that machine. And it's true, no one understands that switch to the 550. But what a dream. One day when I'm old and still probably poor I'll just have to get myself in a 210 with the 550 motor in. What an aerie HJK =D> =P~ =D>
flypiper
Been liked: 32 times
Unread post by flypiper » Thu Dec 21, 2017 7:26 am
Hi to the proud owner of MPA.
Out of interest we brought her into the country and i sold her 12 years later for the 2nd time nice AC.
Regards.
Flying!!!
Return to “Cessna”
