First New Cubby Frame . Now ZU-DRO
- Has thanked: 1 time
- Been thanked: 6 times
Re: First New Cubby Frame . Now ZU-DRO
Nice work Jean.
The photos of the new plane look brilliant.
Reminds me of a face-lift to a vehicle.
The original is just that, the original (that works and flys like a dream),
the face-lift gets the cosmetic upgrades and often looks like a different model.
Keep us posted.
Fly safe.
Keep us posted.
Fly safe.
When once you have tasted flight, you will forever walk the earth with your eyes turned skywards.......Leonardo Da Vinci
- Fower Tousand
- Closest Airfield: FASX
- Has thanked: 1235 times
- Been thanked: 445 times
Thanks Jean-Pierre, the upgrades will have an effect on cruise speeds and therefore fuel flow. Being aerodynamically cleaner has proven to make a difference. We have flown DRO with the original CubbyVW engine and found better cruise speeds. I fully expect the Rotax to do better, being lighter and with the 3blade ground adjustable composite prop, one should find a good cruise/climb compromise.
The next two Cubby`s will have a Rotax 582 blue top, and a Revmaster direct drive .Flaps are also soon to follow.
Jean.
Jean.
Cubby Aircraft Factory.
Cell : 072 6716 240
SACAA Approved Person 402
Cell : 072 6716 240
- Fower Tousand
I took this one for a circuit today, man , what a difference to the old VW powered Cubby. This aircraft is now 33kg lighter than the old model, and with the Rotax engine it jumps into the air . Stall is around 40mph. With the new tail group rudder is more effecient at low speed, and elevator has more authority, with lighter stick forces.Approach to land was at 57mph.
This aircraft weighs 293.4kg empty, no fuel but all engine fluids present.
Jean.
Jean.
Cell : 072 6716 240
Cell : 072 6716 240
- Fower Tousand
This is what she looks like now.
Cell : 072 6716 240
Cell : 072 6716 240
- Closest Airfield: Swakopmund
- Has thanked: 498 times
- Been thanked: 359 times
Ja man - dit is mos hoe n airplane moet lyk - pragtig
Dit gaan net beter lyk hier in die Namib woestyn.
Jean almal wil langs mekaar sit maar as ek en Pieter in die Bushbaby sit is dit n geskouer skuur.
Ek is n voorstander vir die agtermekaar sitplekke - dit voel net reg.
Veels geluk met n fantastiese verbeterde vliegtuig
groete uit die woestyn
Johan
Johan
NAMIBIA FLYING COUNTRY
- Straight and Level
- Closest Airfield: FASH
- Been thanked: 5 times
Baie geluk Jean!! Die verbeteringe wat jy aangebring het laat die aerie sommer regtig spoggerig lyk. Ek hou veral van die nuwe cowling. Daardie vorige cowling met die helfte van die enjin wat uitsteek het maar altyd "odd" gelyk. Nou lyk hy reg, knap gedaan.
So as mens 'n bestelling sou plaas, wat is die prys op daai aerie?
Julian
Based in Somerset West
- Niner Tousand
- Closest Airfield: FYWH
- Has thanked: 1015 times
- Been thanked: 862 times
....Jean, knap gedaan lyk mooi afgerond. Hoe het jy gemaak met die cooling wat nou "internal" is van die cowl?
- Fower Tousand
Guys, thanks for the kind words, I am humbled thereby...truly. I am greatful that this project turned out the way we planned and hoped.
Pilot Dreamer, lead time for a factory built will be 4 months, for a kit 2 and half months.Pricing will depend on engine and instruments. With a Rotax 912 80hp and a basic VFR panel , fly away condition will cost R635 K. A kit will cost R200k excluding instruments and excluding engine mounting kit.
Leo, the cooling of a Rotax 912 such as is in this aircraft is not really rocket science it all fits inside a well designed cowl that has sufficient airflow through it.
Jean.
Jean.
Cell : 072 6716 240
Cell : 072 6716 240
- Niner Tousand
.....ok txs
- Frequent AvComer
- Closest Airfield: RhinoPark
- Has thanked: 162 times
- Been thanked: 25 times
Jean het jy hom met die 582 of 912 gevlieg? Kruis spoed?
Flying feeds the soul!
- Fower Tousand
Hi Jv, hy het n 912 in . I did not try for top speed, only flew 1 circuit. It reached 90mph very quickly ,....and I had throttled back At 75mph 1000fpm climb was no problem.
Will fly more when the weather is better.
Jean.
Jean.
Cell : 072 6716 240
Cell : 072 6716 240
WOW Jean!! That's very reasonable. I think this aerie will do very well.Jean Crous wrote:Guys, thanks for the kind words, I am humbled thereby...truly. I am greatful that this project turned out the way we planned and hoped.
Jean.
Just a quick question, one of the goals that you had for this "upgrade" is for the CoG to be moved slightly in order to solo from the front seat. Did you manage to achieve that?
Julian
- Fower Tousand
Yes Julian, it flies very well from the front seat. Solo flight is now from the front seat, balance is very good indeed.
Jean.
Jean.
Cell : 072 6716 240
Cell : 072 6716 240
Jean Crous wrote:Yes Julian, it flies very well from the front seat. Solo flight is now from the front seat, balance is very good indeed.
Jean.
Julian
