Engine mount
checkride
Been thanked: 1 time
Engine mount
Unread post by checkride »
Hi does anyone have a diagram of the rear engine measurements i.e engine mount points on PDF with measurements.
Has thanked: 61 times
Been thanked: 922 times
Re: Engine mount
Unread post by heisan »
They are available in the installation manual on the Jabiru web site.
Return to “Jabiru Engines”
