Seen at FALA ( Lanseria )
Mistral
Has thanked: 2 times
Been thanked: 16 times
Re: Seen at FALA ( Lanseria )
Unread post by Mistral »
Beech B200, ZS-OYP, 17-Aug-12 :
Mistral
Beech B200, ZS-SDS, 17-Aug-12 :
Mistral
Beech 1900D, ZS-SRZ, 17-Aug-12 :
Mistral
Beech B200, ZS-NXH, 17-Aug-12 :
Mistral
Eurocopter EC 130 B4, ZS-CTE, 17-Aug-12 :
Mistral
The Viper roar - Impala MkI, ZU-IMP, 17-Aug-12 as the sun went down - must have been a magnificent flight :
Anton Nel
Has thanked: 66 times
Been thanked: 86 times
Unread post by Anton Nel »
Malcolm, Great Shots!!!! =D> =D> =D>
Pete
Has thanked: 295 times
Been thanked: 170 times
Unread post by Pete »
Mistral wrote:Cessna T210M, ZS-LYE, 17-Aug-12 :
ZS LYE.. used to be a Turbo 210 M now has the normally aspirated 310 Hp Atlantic Aero IO550P "TI" engine STC installed... magnificent! :D
ddevos
Closest Airfield: FAVV
Has thanked: 12 times
Been thanked: 429 times
Unread post by ddevos »
Pete, according to the information I have, ZS-LYE had an IO-550-C (300HP) when it took part in the PTAR in 2008. I know it had an engine failure in 2004 shortly after a MPI and I assume the IO-550 was then installed. Do you by any chance know when and why that engine would have been replaced with this IO-550-P?
Interesting to note it also had an undercarriage failure in 1998 on the very same day it had a MPI.
Dirk de Vos
Has thanked: 309 times
Been thanked: 1212 times
Unread post by photon »
King Air B200 ZS-BGT of Assmang Ltd. .. 17 Aug 2012
Cessna S550 Citation S/II ZS-CAR .. 17 Aug 2012
Beech 58P Baron ZS-KMZ .. 17 Aug 2012
Cessna 210L Centurion II ZS-MED .. 17 Aug 2012
Mistral
photon wrote:Cessna 210L Centurion II ZS-MED .. 17 Aug 2012
Lekker shot !
ddevos
Totally agree :wink:
Dirk de Vos
