glasair Sportman
Kiewiet Vlok
Airborne from Unmanned field
Closest Airfield: Klerksdorp
Been liked: 12 times
glasair Sportman
Unread post by Kiewiet Vlok » Thu Apr 14, 2016 11:51 pm
Sportsman 2+2
2hours of flying sofar
plane fly of at 275 m when slowly open throtle and lift nose wheel
landing touchdown at 42 knots
Kiewiet Vlok
Re: glasair Sportman
Unread post by Kiewiet Vlok » Thu Apr 14, 2016 11:56 pm
ZU VGK
Kiewiet Vlok
Unread post by Kiewiet Vlok » Fri Apr 15, 2016 12:02 am
Spyker the brainthrust behind the project
Kiewiet Vlok
Unread post by Kiewiet Vlok » Fri Apr 15, 2016 12:08 am
interesting here naca duct for oilcooler lt and air intake right
Kiewiet Vlok
Unread post by Kiewiet Vlok » Thu Jul 13, 2017 11:37 pm
O360 enjin in
Now and then i see these speeds and forgot to check the density alt
I alwayes fly fullthrotle and 2400 rpm
Can any Sportsman flyer help me : what is the best altitude for best groundspeed in no wind ?
Kiewiet Vlok
Unread post by Kiewiet Vlok » Thu Jul 13, 2017 11:42 pm
O360 enjin in
I
Closest Airfield: FAPX
Has liked: 102 times
Been liked: 396 times
Unread post by Chalkie » Fri Jul 14, 2017 4:28 pm
Kiewiet Vlok wrote:O360 enjin in . I alwayes fly fullthrotle and 2400 rpm
Kiewiet, confirm O-360 is a carbureted engine? If so, you should not fly full throttle due to the 'economizer bleed' in a Marvel Schrebler carb. Reduce throttle slightly and economy and performance increases slightly.
I will find the link to the discussion. Here it is... viewtopic.php?f=9&t=157266&p=1602488&hi ... r#p1602488
Kiewiet Vlok
Unread post by Kiewiet Vlok » Sat Jul 22, 2017 1:06 am
Thanks for the tip Chalkie
will surely do it is an o- 360
somewere i read that if not full throtle the air is turbelunt May be it came from my Mooney days (io360)
Kiewiet Vlok
Unread post by Kiewiet Vlok » Sun Jul 23, 2017 7:08 pm
Today back and went flying
throtle about 3/4 of a cm out maniful presure will sligtly rise ( about .02 ) if possable.?
or at least no diferance , still planning feul flow meter
thanks for the tip so far so good
Kiewiet
