Reward / Beloning R10 000
Experimental Aircraft Association of South Africa aims to assist its members with building, flying, and restoring non-type certified aircraft.
Willie
Closest Airfield: Hippo Pools
Has thanked: 4 times
Been thanked: 3 times
Unread post by Willie »
Vir iemand wat my binne twee weke 'n ATF en registrasie sertifikaat kan gee vir my Skyjeep, ZU - DSV,wat by Philip van Bundu Aviation staan. Hy kom nie reg met CAA nie.
ZS-UJC Hatz Bi-plane
ZS-UGS Evans VP 2
KR2 ZS-UNC
KR2 ZS- UUJ
Jabiru J400 ZU-VHB
Zenith 601 XL ZU-DVN
Return to “EAA of South Africa”
