"Antic" static display model- Completed
Theuns v V
Been liked: 189 times
Unread post by Theuns v V » Sun Aug 07, 2016 4:08 pm
I was commisioned to build a series of vintage looking static display models for a restaurant group.
We decided to go with something that looks like the proctor antic monoplanes as a guide.
I designed a 2.2m span model that will fit in with the theme of the restaurant "Old time Italy"
Therefore the model depicts the early years of air racing and will be named "Grande gara aria Italiano 1911" - great Italian air race 1911
T
Theuns v V
Re: "Antic" static display model
Unread post by Theuns v V » Sun Aug 07, 2016 4:16 pm
I made wheels from discs of 3mm balsa shees glued to make a plywood.
Then I glued spokes to the base and covered it with solartex. It as then painted with humbrol "linnen" paint and the shadows of the spokes were pre-shaded under the linnen paint to show through.
Although it seems overdone, just like in the theatre you need to have it like that because of the lighting that it would be under in the display area
Then I cut and glued a length of 14mm rubber hose to form a tire. The joint was then filled and sanded followed by a coat of Tamiya's rubber black
T
Theuns v V
Unread post by Theuns v V » Sun Aug 07, 2016 4:21 pm
the open rear fuse structure is made up from 10mm round hardwood dowls, each joint needed to be 1/2 filed out to make a good mitre joint. As an extra safety feature I drilled a 2.5mm hole in each joint and glued a piece of toothpick in it
The front part of the fuse is from ply.
It is not a flying model but I still needed to design the airframe to take the strain of being suspended form years....
T
Slopehead
Airborne from Unmanned field
Closest Airfield: Howick Model Fliers Club
Unread post by Slopehead » Sun Aug 07, 2016 4:57 pm
Subscribed with interest, fascinating era of aviation being recreated.
Slopehead
Theuns v V
Unread post by Theuns v V » Wed Aug 10, 2016 2:47 pm
a completed fuselage side.
The silver X-braces are 2mm dowls painted silver.
T
SNIPER
Has liked: 561 times
Been liked: 108 times
Unread post by SNIPER » Wed Aug 10, 2016 3:58 pm
Theuns this will be very cool.
Barry Wolmarans
rudolphschar
Closest Airfield: Worcester
Has liked: 26 times
Been liked: 14 times
Unread post by rudolphschar » Wed Aug 10, 2016 4:55 pm
Wow, the detail is amazing. I will be following this thread with lots of attention.
Rudolph Scharneck
SF-25 Motorfalke, GPL
The problem is not the problem, the problem is your attitude about the problem.
Theuns v V
Unread post by Theuns v V » Wed Aug 10, 2016 5:20 pm
When I am trusted to build something and get paid for it I need to give a good product otherwize I will not get repeat buiseness :)
Hoping to square up the fuse tonight.
T
Slopehead
Unread post by Slopehead » Fri Aug 12, 2016 12:19 pm
Very impressive Theuns,
As per your previous links, you have done this before =D>
Have a productive weekend
Slopehead
Theuns v V
Unread post by Theuns v V » Fri Aug 12, 2016 12:47 pm
Has to be a build weekend with the deadline looming closer....
fly scale
Closest Airfield: Home
Unread post by fly scale » Fri Aug 12, 2016 1:17 pm
Hallo oom Theuns
Ek het 2 Antic's, een met 91FS en die ander met DLE111. Dus net jammer daar was nooit n Full Size Airplane nie, hy lyk mooi en vlieg lekker.
Sterkte met die bou en lyk baie mooi sover.
Groete
FS
Theuns v V
Unread post by Theuns v V » Fri Aug 12, 2016 1:18 pm
Baie nice, hierdie modelle gaan nooit vlieg nie, net display.
T
Theuns v V
Unread post by Theuns v V » Sat Aug 13, 2016 6:52 pm
Starting to look like a fuselage...
T
Theuns v V
Unread post by Theuns v V » Sun Aug 14, 2016 5:14 pm
Stab on the building board....
T
Slopehead
Unread post by Slopehead » Sun Aug 14, 2016 8:11 pm
A rare talent in this day and age, awesome work Theuns.
May this inspire all of us to get back to the building board :shock:
Slopehead
Return to “General Model Aircraft Chatter”
