Upington fuel
cam30683
Closest Airfield: Anywhere
Upington fuel
Unread post by cam30683 » Fri Aug 12, 2016 11:49 am
Hi all
Does anyone know if upington has Avgas or do they have a number I can call. I've tried their towers landline (which I normally use) but the last couple days it hasn't been connecting.
Thanks
Cameron
Segg
Has liked: 366 times
Been liked: 77 times
Re: Upington fuel
Unread post by Segg » Fri Aug 12, 2016 12:02 pm
According to Easy Cockpit
cam30683
Re: Upington fuel
Unread post by cam30683 » Fri Aug 12, 2016 7:45 pm
Thank you kindly!
Ernstheymans
Re: Upington fuel
Unread post by Ernstheymans » Fri Aug 12, 2016 8:18 pm
Been there 2 weeks ago, just tell TWR that you require fuel on initial contact. Truck will fuel you at your parking space.
Ernst
CV580
Closest Airfield: cpt intl
Re: Upington fuel
Unread post by CV580 » Mon Aug 15, 2016 2:31 pm
What does one do if you need fuel at Askham and Upington will not refuel your Jerry-cans?
opsmike
Been liked: 99 times
Re: Upington fuel
Unread post by opsmike » Mon Aug 15, 2016 3:00 pm
CV580 wrote:What does one do if you need fuel at Askham and Upington will not refuel your Jerry-cans?
Very few airports will provide fuel into anything but an aircraft due to liability reasons.
Airports are where it happens
Beek
Re: Upington fuel
Unread post by Beek » Mon Aug 15, 2016 4:03 pm
Spoke to them 2 days ago, they have a supply problem at the moment. Very limited stock avail on Avagas...good change they will run dry! :(
Beek
Re: Upington fuel
Unread post by Beek » Mon Aug 15, 2016 4:04 pm
Spoke to them 2 days ago, they have a supply problem at the moment. Very limited stock avail on Avgas...good change they will run dry! :(
Mauler
Closest Airfield: Vans
Re: Upington fuel
Unread post by Mauler » Mon Aug 15, 2016 4:46 pm
Is this due to jerry-cans being more litigious than aircraft?
I don't get it. I had the same problem years ago when I flew a friend to Swakopmund to collect his Diamond Katana there. We had to borrow a pipe, siphon fuel from the plane into the cans, and then push the plane back to the pumps to fill it again. The fuel in the cans had come from the same pumps, but had to do the trip via the aircraft tanks.
Sometimes I have severe concerns about the sanity of some people who are "in aviation".
Rotor kop
Closest Airfield: OR Thambo
Has liked: 1907 times
Been liked: 304 times
Re: Upington fuel
Unread post by Rotor kop » Mon Aug 15, 2016 9:14 pm
Agree - really stupid mentality driven by some regulation that an ignorant "expert" put together....
DawieBotes
Flaps set for Take off
Closest Airfield: Heidelberg
Re: Upington fuel
Unread post by DawieBotes » Mon Aug 15, 2016 9:58 pm
The reason, as urban legends go, that they don't want to throw avgas in jerry can, is because drag racers can then easilly get their hands on it. :)
But joking aside, so far no one send me packing yet when I show up at the pump with my 2 jerries and ask for just a little fuel to get my aerie off the ground.
Rotor kop
Re: Upington fuel
Unread post by Rotor kop » Tue May 17, 2022 4:44 pm
Needing Avgas and W100Plus oil. Anyone have a contact for upington please [-o<
Willemkrullie
Closest Airfield: fash
Re: Upington fuel
Unread post by Willemkrullie » Wed May 18, 2022 3:42 pm
Hi Rotor kop,
Contact James @ 082 808 1696 for fuel queries at FAUP. Very helpful - fast fuel service as well after landing.
Last edited by Willemkrullie on Fri May 20, 2022 10:18 am, edited 1 time in total.
These users liked the author Willemkrullie for the post:
Rotor kop
Rotor kop
Re: Upington fuel
Unread post by Rotor kop » Wed May 18, 2022 8:20 pm
Hi Rotor kop,
Contact James @ 082 808 1696 for fuel queries at FAUP. Very helpful - fast fuel service as well when landing.
Thank you =D>
JCA
Closest Airfield: Krugersdorp
Has liked: 47 times
Been liked: 173 times
Re: Upington fuel
Unread post by JCA » Thu May 19, 2022 9:53 pm
"fast fuel service as well when landing"
Pretty certain the fuel service will be fast if they do it while you are landing......... :lol:
These users liked the author JCA for the post:
Willemkrullie
