Strapping Cameras to a Jabi
Our informal clubhouse for Jabiru Enthusiasts.
DawieBotes
Flaps set for Take off
Closest Airfield: Heidelberg
Unread post by DawieBotes » Wed Aug 17, 2016 1:11 pm
How to you guys normally strap Gopro's to the Jabi? Does the weight difference req a rebalancing?
Thinking of strapping a Gopro the the wing strut.
Tnx!
Flooi
Closest Airfield: FAHG
Has liked: 56 times
Been liked: 24 times
Re: Strapping Cameras to a Jabi
Unread post by Flooi » Wed Aug 17, 2016 1:28 pm
Strap die ding vas en vlieg- te lig vir enige probleme.
Hennie van Zyl
DawieBotes
Unread post by DawieBotes » Wed Aug 17, 2016 2:05 pm
Cool. So gedink. :)
pietmeyer
Been liked: 42 times
Unread post by pietmeyer » Wed Aug 17, 2016 3:22 pm
Nog nooit n probleem met myne gehad ne. Strap vas en vlieg die ding :D
https://vimeo.com/159795288
ZU-DUU Jabi J400 (FAWB)
Flooi
Has liked: 56 times
Unread post by Flooi » Thu Aug 18, 2016 10:44 am
Not a Jabi, but after many experiments, I found this mounting for GOPRO, gave me best results. :D
Hennie van Zyl
Cloud Base
Closest Airfield: Komani
Unread post by Cloud Base » Fri Aug 19, 2016 2:41 pm
On top of the horizontal stab
gives a good view of the flight controls
Pilots take no special joy in walking. Pilots like flying.
Neil Armstrong
DawieBotes
Unread post by DawieBotes » Sat Aug 27, 2016 7:53 pm
Going to try that on the back. Looks great. Did a couple different angles already. Because our Jabi is a partnership plane I didn't want to permanently stick any mounts on it, so strapping onto the wing strud works very well for a sideways view of the pilot as well as forward looking. Going to try a couple of different angels next time. Just need to remember to check the batteries on the cameras before the time. Only got 1 camera's footage :(
https://youtu.be/e_VYme8E408
BigglesSA
Has liked: 23 times
Unread post by BigglesSA » Thu Sep 08, 2016 11:20 am
Years ago landing at Pienaars Poort. Old cellphone video placed by my passenger.
https://youtu.be/95AK2kpw9Ss
Groetnis
Francois Gouws
Has liked: 16 times
Been liked: 360 times
Unread post by cage » Fri Sep 09, 2016 9:05 am
Not sure it's a great idea to attach anything to a surface used to generate lift.
There are many clamps available for attaching to supports etc.
I've always preferred placing them in cockpit or attach a mount under the belly (they can be removed, carefully, with a hairdryer).
Marius Schrenk
Has liked: 189 times
Been liked: 130 times
Unread post by Marius Schrenk » Fri Sep 09, 2016 5:06 pm
cage wrote:Not sure it's a great idea to attach anything to a surface used to generate lift.
:? If you put it on a heli's "surface used to generate lift" the picture would be a little distorted......like Mike Schutte's blue light.......ag no you are to young to know the joke....sorry. :wink:
Has liked: 16 times
Unread post by cage » Fri Sep 09, 2016 5:08 pm
All I remember about big Mike is him trying to klap Leon Schuster a lot :D
DawieBotes
Unread post by DawieBotes » Sun Nov 20, 2016 6:29 pm
Tried a couple of different angles, just strapping the cameras on different points on the struts using velcro straps.
https://www.youtube.com/watch?v=cqbrLjgf5hw
Just did some flips from Heidelberg, Vereeniging, Panorama and Circus. :)
Love the Jabi!
ZuluBen
Unread post by ZuluBen » Sun Nov 20, 2016 7:03 pm
Lekker man, lekker! 8)
Neville Ferreira
Been liked: 39 times
Unread post by Neville Ferreira » Sun Nov 20, 2016 7:34 pm
Using the standard supplied mounting option with GoPro or 360Fly are good enough up to 400Km/h or more, provided you have cleaned the surface area before sticking the mount on that surface.
From experience you do not want to mount a camera on the leading edge as this will disturb the airflow and will increase the stall speed of that wing.
https://www.facebook.com/neville.ferrei ... 1470283169
DawieBotes
Unread post by DawieBotes » Mon Nov 21, 2016 7:11 pm
Neville Ferreira wrote:Using the standard supplied mounting option with GoPro or 360Fly are good enough up to 400Km/h or more, provided you have cleaned the surface area before sticking the mount on that surface.
Really nice video! I would be too scared my GoPro will fly off into the distance without me! That's why I got a bunch of cheapy Chinese cameras. Not even close the quality, but I would loose max R500 if it falls off the plane and not R8000... :) GoPro inside rather :P
Return to “Jabiru Club of South Africa”
