Rotax 912 not stopping
Farley
Forgot to remove the chocks!
Closest Airfield: Panorama airfield
Unread post by Farley » Thu Aug 25, 2016 8:16 am
I recently had a problem with one CDI not earthing and stopping the motor. The repair was to ground the charging circuit for that particular module. The fix was a 4.7R resistor tapped in to the charging wire coming from the stator and then grounding it thru the existing kill switch. I did not want to just ground the charging coil directly so hence the resistor.
Ducati use excactly the same inside their module , they use a MOSFET T1 and R3 circuit diagram attached
Farley
Re: Rotax 912 not stopping
Unread post by Farley » Fri Jul 05, 2019 2:27 pm
nearly finished
Has liked: 53 times
Been liked: 46 times
Unread post by V5 - LEO » Fri Jul 05, 2019 4:10 pm
.....well that is very neat - gonna save your particulars if ever I need help on a Rotax wiring/electrical issue!
Orthin Opter
Closest Airfield: Tranquility
Has liked: 17 times
Been liked: 34 times
Unread post by Orthin Opter » Mon Jul 08, 2019 6:30 pm
Now LycoSaurus are much more simple. Just ground the wire, no resistor needed. :wink: OH sorry, I forgot. you pull the red knob out. #-o
Has liked: 263 times
Been liked: 198 times
Unread post by Ugly Duckling » Tue Jul 09, 2019 12:03 pm
The Ducati TIF is not downloading. :cry: Resave it to a JPG file and reload it.
