Air induction Jabiru on Cheetah
Tonydc
Fuelling up
Closest Airfield: Nigel
Unread post by Tonydc »
Hi.
Any advise or pics on your air induction on your Cheetah with a Jabiru 2200 motor. Any comments will be highly appreciated.
Thanks
Return to “Jabiru Engines”
