Engine Cooling for the Jabiru engine
Steve
Closest Airfield: Wings Park
Has thanked: 17 times
Been thanked: 119 times
Unread post by Steve »
This has been a topic that most Jabiru engine owners show concern and engine cooling is an important thing to ensure is done right in preserving the engine.
I notice that AeroConversions produces a baffle kit for use with the 3300 motor in the sonex aircraft......
http://www.sonexaircraft.com/press/rele ... 13007.html
Perhaps this is another area that the suppliers of the post Camit engine arena could also address and improve engine cooling?
Steve Onions
Marius Schrenk
Has thanked: 79 times
Been thanked: 58 times
Re: Engine Cooling for the Jabiru engine
I see there is a Chinese knock off on the way.....maybe one should wait for it. :wink: :lol:
buffet
Closest Airfield: east london
Unread post by buffet »
Price and is it available for the 2200 jab engine?
lessersg
Post Take off checks
Closest Airfield: Cape Town
Been thanked: 7 times
Unread post by lessersg »
Its all the same mess, why go to the hassle of making a plenum and not doing it properly .Busy with a full plenum mould for the 3300, not ducts.
Jean Crous
Closest Airfield: FASX
Has thanked: 1185 times
Been thanked: 408 times
Unread post by Jean Crous »
Contact Philip at Bundu Aviation, he has the answer for the cooling of a Jab motor.
Jean.
Cubby Aircraft Factory.
Cell : 072 6716 240
SACAA Approved Person 402
Flooi
Closest Airfield: Fahg
Has thanked: 103 times
Been thanked: 57 times
Unread post by Flooi »
Jean Crous wrote:Contact Philip at Bundu Aviation, he has the answer for the cooling of a Jab motor.
Jean.
how does one contact him?
Has thanked: 1784 times
Been thanked: 1994 times
Jean.
http://www.bunduaviation.com/index_files/Page441.htm
Paul Sabatier
Has thanked: 61 times
Been thanked: 922 times
Unread post by heisan »
Ugly Duckling wrote:
Jean.
He is doing a maintenance tour in Kenya at the moment, so do not expect an immediate answer.
lessersg
Heres the plug ready tomorrow going to make the mould. I think this will work very well, What you all think?
lessersg
Done, now top dress it and do the bottom pieces the make the first product...Think Ill make a nice carbon one first. :D :D
lessersg
End result. Might make the first one this weekend will see if time allows.
Marius Schrenk
So what's the end result ?
lessersg
Ok,
The mold is done, did not have the time to make the first product , will be done when I get back to Cape Town in 3 weeks. I'm optimistic that this will work. :) :) If I can drop the temps by 10 c all around its a winner.
Mikee
Closest Airfield: A grass strip
Has thanked: 10 times
Been thanked: 3 times
Unread post by Mikee »
That mold looks great, what are your temps running at at present?
lessersg
Temps,
Between 140-162. Cylinder 2 and 3 175-177 Max being the hottest on the climb. Cylinder 2 and 3 remain the hottest in the cruise between 150-160. ( 12.6 AFR)
No too bad but plenty room for improvement.
Return to “Jabiru Engines”
