Engine Cooling for the Jabiru engine
Patrick H
Closest Airfield: Wings Park
Re: Engine Cooling for the Jabiru engine
Unread post by Patrick H »
I'm really keen to see the improvement. I think you are on the right track. Cool everything not just the cylinders and heads. I'll be your first customer. Well done for the initiative. Please keep us posted.
lessersg
Post Take off checks
Closest Airfield: Cape Town
Been thanked: 7 times
Unread post by lessersg »
Yea,
That was my thinking as well. Radiated heat from the crank case either way Im sure is not helping. System seems to work quite well on any other air cooler engine why not Jabiru...anyway we will see.
J430
Closest Airfield: Australia
Unread post by J430 »
This has been done before using aluminium on a Bristell with a Jabiru 3300 in Australia. Much time was spent by the LAME's with lots of little modifications to get the temps all equal. The end result was 120-125c all round.
Patrick H
That's excellent on a Jab 6. With those temps it will last forever. Heat is the biggest killer of the Jab.
lessersg
Below was the last flight we did with OAT at 32 deg. So with solving all the leaks we can from the ram ducts and NACA duct plus a small mod the CSP airfoil this was the result. Circuit work touch and go's brought the highest temp to 158 C.
Im sure the plenum will make a huge difference. Still not finished
I would say a happy engine .....max power no messing around...
AJW
Closest Airfield: FARB
Has thanked: 28 times
Been thanked: 42 times
Unread post by AJW »
lessersg wrote:Below was the last flight we did with OAT at 32 deg. So with solving all the leaks we can from the ram ducts and NACA duct plus a small mod the CSP airfoil this was the result. Circuit work touch and go's brought the highest temp to 158 C.
Sorry if I missed it, but what was your altitude, fuel flow and speed ?
Please.
Be safe
Abrie
lessersg
Climb out ...its on the IEFIS, Ground temp 35C
Pepler
Closest Airfield: FAFK
Been thanked: 4 times
Unread post by Pepler »
Is this "mod" in production already. When can we order =D>
Bring it to Surherland on the 24 & 25 for hot and high please.
http://avcom.co.za/phpBB3/viewtopic.php?f=307&t=197861
ZU-FBI
lessersg
Im doing the first layup tomorrow. So hopefully testing early next week.
lessersg
Started the fitting and adjustments today.....
lessersg
Progress,
Hope to finish off by wednesday or so, but looking good everything fits nicely.
J430
It's going to be very interesting to see how that beast performs!!
lessersg
Last few items to do , 4 x baffle plates for un der the cylinders will be done tomorrow these will be made from .6 mm aluminium Final fitting tomorrow and hopefully testing Friday. So far I have three moulds, 5 templates which make up this plenum.
The current mould will not be the final product, this one now is the test bed. The original mould will be modified, and a new plug made from it should the full plenum work. No reason why it shouldn't be a success.
The top piece, main section and the bottom intakes will be common to all 6 cylinder jabs. The side plates will have to be fitted. Anyway when all is done and working ill put something together so all can see how this goes together. Should not take more than an afternoon to install.
lessersg
FYI, what we found during the whole exercise of improving the cooling that by eliminating the air leaking past the oil cooler , sides and top the temps drops about 10 c all around. So I can quite easily say that sealing that and sealing all the holes on the ram air ducts dropped temps by early 15 c. The originals have huge holes on the left rear cylinder 5 and look on the right side rear cylinder 6 top. Theres at least a 10mm gap on top off the cylinder and at the rear this doesn't help for cooling at all.
In front on the right side cylinder 2, 5-10 mm gap---air takes the shortest route. We did not mess with the factory setup of the deflectors inside the ram ducts at all.
lessersg
Finished the fitting today looks good fits nicely. Two small issues at the back both left and right. Will make up plates and install tomorrow holes are a bit big. Need to drill the holes for the plug leads and install grommets and fit the baffle plates under between the cylinders. Then testing. For the test will seal around the starter motor and right rear with some Red Devil Silicone. Version two will have rubber edging. Plus the starter motor will be under the plenum , theres enough clearance between the starter and the underside off the cowl. V 2 will also have a depression on the top of the cowl for the oil filler cap and cowl latch mechanism.
Return to “Jabiru Engines”
