Engine Cooling for the Jabiru engine
lessersg
Post Take off checks
Closest Airfield: Cape Town
Been thanked: 7 times
Re: Engine Cooling for the Jabiru engine
Unread post by lessersg »
So guys seems the plenum works, this is a full power climb out AOT 30 deg. Dont worry about Fuel flow, oil pressure etc, glitch with the IEFIS again.
Still room for improvement, front of the plenum needs to be blocked but that's about all. I'm sure we can still drop these temps further
Steve
Closest Airfield: Wings Park
Has thanked: 17 times
Been thanked: 119 times
Unread post by Steve »
So any indication when the units will be available as a kit to fit and what the price will be?
Steve Onions
lessersg
Steve wrote:So any indication when the units will be available as a kit to fit and what the price will be?
Steve this was the prototype to prove concept. Now that we know it works we need to make a few changes.
1. Front on plenum needs to be changed to stop bleed air moving forward.
2. Needs to be designed so bottom ducts can easly be installed. Right now as it stands requires a bit of glass work. Not ideal, but I have a few ideas
So.. Have one more mold to make from that the final plug will be made using tooling resin. I have no idea what the cost will be all depends on material cost per plenum, have not even thought of that yet. I have to make sure this works 100% first must be 100% plug and play lol dont want our jabi owners to still mess around trying to make it work. So Id say about 3-4 months before Im ready to say come and get them lol...
Marius Schrenk
Has thanked: 79 times
Been thanked: 58 times
Thank you very much for the R&D. =D> =D>
Patrick H
Unread post by Patrick H »
Very big well done on sorting the JAB cooling problem out on gen 3 and earlier models. I really think you onto a winner here. =D>
lessersg
Patrick H wrote:Very big well done on sorting the JAB cooling problem out on gen 3 and earlier models. I really think you onto a winner here. =D>
I really hope so, think by cooling the whole engine and not just the heads is also helping plenty. Our oil temps dropped by 10 c as well in the cruise.
Its important to remember that the results are only as good as the installation, meaning that leaks have to be stopped. Same with the current ram air ducts. After sealing ours we managed to drop the temps substantially.
J430
Closest Airfield: Australia
Unread post by J430 »
I'm surprised to hear your oil temp dropped... are you running the big gold square oil cooler? I find that it works way too well, never getting anywhere near above the recommended temp, which is why I fitted the TOCA oil thermostat.
lessersg
Nope standard oil cooler.....
lessersg
Made a small modification to the front of the plenum, think I have it done now. Will see if I can get the new mold done in the next few weeks or so just very busy right now.
Flooi
Closest Airfield: Fahg
Has thanked: 103 times
Been thanked: 57 times
Unread post by Flooi »
Now another silly question.... why are the users.... the customers.... working so hard to
sort out a problem that is decades old? Why has the manufacturer not done this ages ago?
Simply cannot figure this out..... 8-[
lessersg
Flooi wrote:Now another silly question.... why are the users.... the customers.... working so hard to
Maybe because they haven't realized there is a problem. Maybe I'm the only one having this problem because I have Fuel Injection rather than the Antiquated Bing fiasco....who knows. ANYWAY..my problem is sorted.
Might change a few things later if I have the time. Thinking off maybe having the top of the plenum removable, easier for maintenance as its a bit of a bitch removing the full plenum.
lessersg
I have a question for the boffins.
Truth be told please------
Speaking to an instrument technician a few weeks ago, he indicated that it is the norm for the RDAC or any other make to measure the ambient temperature inside the cowl and add this to the CHT and EGT temp reading. Is anyone familiar with this equipment or can confirm this statement.
I do know that this happens with the MGL RDAC unless I misunderstood I did ask three times for an explanation ......
GPsucks
Flaps set for Take off
Closest Airfield: Kazakistan
Unread post by GPsucks »
lessersg wrote:I have a question for the boffins.
Sounds like BS to me. Park your aerie in the sun and check CHT and EGT readings, the EFIS should indicate OAT or a bit more on both, so 'cowl' temperature is already displayed. EGT, CHT will indicate respective temperature just as a tyre pressure gauge indicates pressure in the tyre which is gauge pressure because it measures 0 psi at 'rest' but the pressure on the gauge would be 14.7 PSI at sea level on a 'standard' day. (A bit less here in GP) In other words, a tyre pressure gauge indicates the difference between the pressure outside the tyre and the pressure within the tyre. The EGT CHT gauge would do the same IE measure the differential between cowl temp and EGT CHT, not add cowl temp to the value, rather subtract it.
Has thanked: 61 times
Been thanked: 922 times
Unread post by heisan »
A thermocouple (as used to measure CHT and EGT) measures the difference in temperature between the probe and the 'cold junction' (the point where the thermocouple wire connects to the display)*.
Old temperature gages just estimate environmental temp and display the result (so if the cold junction is 10 degrees hotter than normal, it will show 10 degrees *colder* than expected).
Modern EFIS systems though a re 'cold junction compensated' - there is a separate thermometer that measures that absolute temperature of the cold junction, adds the thermocouple relative temperature, and displays the real temperature (irrespective of environment temperature).
The MGL RDAC *is* cold junction compensated, so should be accurate in all conditions.
* NOTE: Some people extend thermocouple wires with copper wire. This moves the 'cold junction' to the join in the wire, and the resulting reading will be off by the difference between the temperature at the junction and the temperature at the instrument.
lessersg
So what you saying is my EFIS is displaying the total value Cowl temp plus EGT and CHT? Why would they do this? I want to see what is at the probe. Suppose the probe will pick up ambient ( in the cowl ) as well. Its called cold junction compensation so I have been told. Was told if the probe is disconnected from the RDAC you would see terminal temperature. So that valve would be subtracted from the value seen on the IEFIS....Well that sucks .....Why is this done.
Return to “Jabiru Engines”
