Jabi battery
FlyFalke
Closest Airfield: Potch
Has thanked: 5 times
Been thanked: 5 times
Jabi battery
Unread post by FlyFalke »
It seems that I need a new battery as all the problems with starting has now come to %67^$& my flying life.
My Jabi 2200 won't crank over unless I boost the battery. Tried/tested and sorted out all the other bits so now the battery is the only guilty party left over.
Where do I buy a new battery ? and what battery ?
I don't think the battery now fitted is a standard battery.
How usefull is buying a new stronger starter motor ? and is it worth the expense ?
Any advise please / asseblief ? wil graag weer in die lug kom.
Flooi
Closest Airfield: Fahg
Has thanked: 103 times
Been thanked: 57 times
Re: Jabi battery
Unread post by Flooi »
There is a starter motor upgrade available. There is also the option of a better battery- which was my choice.
I would advise you to speak to the factory or to ZuluBen on this forum.
I regularly put my battery on charger for about 1 hour- especially in winter. Another idea which works well, is to
have a spare battery- fully charged- that you take to the hangar when you go flying. Connect it to the fitted battery
before starting.
FlyFalke
Re: Jabi battery
Hi - thanks for the reply. I will go for the better battery option first as the uprated starter is almost R10k.
The engine start if I jump it with a battery to boost.
Does anybody know what the model/code for the larger capacity battery is. I was told that it is all about the CCA ( cold cranking output ) of the battery. The higher the CCA is rated the less likely one is to have problems.
Flooi
Re: Jabi battery
Ek het een van hierdie. Geen verdere probleme
Has thanked: 1022 times
Been thanked: 868 times
Re: Jabi battery
Unread post by V5 - LEO »
.......sooo did you come right and what did you get where?
FlyFalke
Re: Jabi battery
I have ordered a battery and will test during the course of next week - will give you feedback then V5-LEO
Marius Schrenk
Has thanked: 75 times
Been thanked: 58 times
Re: Jabi battery
Flooi wrote:Ek het een van hierdie. Geen verdere probleme
Hoeveel en waar ? [-o<
Flooi
Re: Jabi battery
Marius, ek het by i Motobatt agent in Pretoria gekoop lank gelede. Kan nie meer onthou waar nie.
Ek het gestart na 2 maande se staan sonder probleem op i vorige vliegtuig. Kos baie, maar moeite werd.
http://www.m.motobatt.com/africa
Hennie
Marius Schrenk
Re: Jabi battery
Hennie
Baie dankie Hennie....Ek het een opgespoor. Kos 50 % van die Amerikaanse battery.....lyk goed vervaardig....weeg 200g minder.....ek sal niks verder se voor oor n jaar nie. :idea:Oppi box se dit voorsien uit USA.....onner die battery.....made in China. 8-[
Return to “Jabiru Engines”
