Jabiru taildragger rating
Duane Mouton
Power off Glide
Unread post by Duane Mouton » Tue May 23, 2017 11:42 am
Hi guys,
I would like to ask if anyone here could give me some advice. I am purely gathering information here for now. I have come across a Jabiru taildragger, and I would like to know where I could get a taildragger rating and the rating on this aerie? I have not been able to find any instructor rated specifically on these machines. The guys at the factory don't actually have anyone they know of either.
The guys are LSAT said I shouldn't specifically need to do a rating on this aerie, but if I hold a taildragger rating as well as the Jab1 rating I should be allowed to fly this aircraft, is that correct?
Thanks in advance.
Duane
Justus Venter
Mags Dead Cut
Closest Airfield: FAKT
Re: Jabiru taildragger rating
Unread post by Justus Venter » Wed May 24, 2017 8:01 pm
Find out from the factory what the ICAO type designator for the taildragger Jabi is. If it is 'JABI' then you don't need an additional rating. As far as I know there are only 3 designators, JABI, JAB2, and JAB4, so you should be covered.
There are several guys at Kitty Hawk and Petit that can help you out with a taildragger rating.
The taildragger Jabi is not an easy aircraft to control on the ground as the rudder is VERY small and you don't have differential brakes. Find someone with a Bushbaby without differential brakes and fly as many circuits as you can. The handling characteristics should be fairly close although I do believe the Jabi will keep you a little busier :)
Induna
Closest Airfield: FASD
Has liked: 105 times
Been liked: 127 times
Unread post by Induna » Thu May 25, 2017 12:50 pm
The Jabi Taildraggers looks very pretty! I think there are very few of them in RSA though, but I would also like to own one... one day!
Have fun!
Jacques
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
ZuluBen
Unread post by ZuluBen » Tue Jun 06, 2017 10:13 pm
According to my License paper from SACAA my JAB1 rating includes the Taildragger, provided that you have an initial taildragger rating off course.
Slippery little beasts, and herein lays the problem. There is no gentle stalling of the wing, she will fly brilliant and then dump you on the ground.
So you better be in contact or very close proximity of Terra Firma when that happens... 8-[
skyvan
Has liked: 9 times
Been liked: 18 times
Unread post by skyvan » Mon Oct 16, 2017 6:56 am
I did a few hours on the first SA Jabiru taildragger, it had differential drum brakes, that were almost useless. I kept bending the brake pedals if there was any crosswind!
Also, because there is almost no fuselage behind the CG, you have very little dynamic stability, so you have to make sure you put her down straight every time.
I would recommend that if you are going to fly it, please be very current as a tailwheel pilot.
Apart from getting it back on the ground, she was a very nice plane to fly.
Induna
Unread post by Induna » Wed Dec 20, 2017 9:56 am
Are there any taildragger Jabis around thats for sale?
Just interest..
Jacques
ZS-WSW | Sonerai 2L
Duane Mouton
Power off Glide
Unread post by Duane Mouton » Wed Dec 20, 2017 12:46 pm
Induna wrote:Are there any taildragger Jabis around thats for sale?
Just interest..
Jacques
Standby will get back to you
Induna
Unread post by Induna » Wed Feb 20, 2019 6:54 pm
How many TD jabis are in SA? I love the looks. It would be interesting to hear the ground handling.
I heard she is a handful on the ground..
ZS-WSW | Sonerai 2L
ZuluBen
Unread post by ZuluBen » Wed Feb 20, 2019 10:54 pm
None left as far as I know..
The last one was ZU OOM and she got converted to trike configuration about a year or so ago
Has liked: 262 times
Been liked: 1400 times
Unread post by Bearcat » Thu Feb 21, 2019 7:02 am
Jabiru ZU-CJV
April 2009
Unread post by Bearcat » Thu Feb 21, 2019 7:10 am
Jabiru ZU-CRV
May 2007
Has liked: 246 times
Been liked: 270 times
Unread post by V5 - LEO » Thu Feb 21, 2019 7:59 am
....now that looks so much better
