Hi Guys,
I have a J170 that has developed stiff elevator free movement.
Is this cable lubrication or to do with trim connection.
If it is lubrication how would one go about it.
Regards Foxdog
Jabiru J170 elevator control
- Closest Airfield: Fahg
- Has thanked: 103 times
- Been thanked: 57 times
Re: Jabiru J170 elevator control
Service bltn
- Tree Tousand
- Closest Airfield: FQNC
- Been thanked: 7 times
Sorry for the drift, can anyone explain to me how the elevator trim works in the Jab?
I only have 5 hours in the Jab from 2 years ago, and I was told that the trim works by applying spring or bungee pressure to the elevator cable..... Is this true?
Mark
AKA "happyslipper", "slappykipper" ... etc..
- Fower Tousand
- Closest Airfield: Wings Park
- Has thanked: 19 times
- Been thanked: 135 times
Yes, is uses a spring offset trim system. The Trim offset can be adjusted as illustrated below:-
The illustration below shows how the offset pressure is achieved
Steve Onions
- Tree Tousand
Brilliant explanation - thank you Steve.
Mark
