Jab 3300 runs on 5 cylinders after standing for a week
JontyL
Flaps set for Take off
Unread post by JontyL »
Any body know what would cause my jab 3300's cylinder no:5 to not fire when started after a weeks rest. If revs increased to 1700 rpm no:5 egt comes alive and runs normally. Then runs normally for that flight. The issue returns after the next weeks rest. Not related to the mags. I thought it might be sticky valves. Has anyone had a similar problem. What's the solution?
Tail down, face up while taxiing
Induna
Closest Airfield: FASD
Has thanked: 149 times
Been thanked: 177 times
Re: Jab 3300 runs on 5 cylinders after standing for a week
Unread post by Induna »
could it be that the mixture is running rich on your engine in that particular cylinder and that its plug fouling that causes this?
I know the Jabi has got a single Bing carb which is partially altitude compensating and without a mixture control, but could it be that it is running very rich for some reason?
Are you flying avgas or mogas?
Jacques
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
ZU-FBA | Sonex Aircraft Waiex
lessersg
Post Take off checks
Closest Airfield: Cape Town
Been thanked: 7 times
Unread post by lessersg »
Could be a sticky valve. I would eliminate plugs and leads first . Could be moisture in the dizzy , remove and clean . If all else fails do a blow by on that cylinder
JontyL
Thanks will check those items.
Aerosan
Fuelling up
Unread post by Aerosan »
Hi JontyL
I have the exact same problem, same cylinder etc.
Have you found a solution?
Sanna
arm maar eerlik
JontyL
Hi Aerosan.
Was told it was a sticky hydraulic lifter and It should correct itself. The day I took it for a blow by test It was gone and fixed itself. Hasn't happened again. Blowbys are all 100%
Marius Schrenk
Has thanked: 79 times
Been thanked: 58 times
Double transmission :oops:
Last edited by Marius Schrenk on Tue Dec 19, 2017 5:19 pm, edited 1 time in total.
Marius Schrenk
Marius Schrenk wrote:
JontyL wrote:Hi Aerosan.
and the vibration is it still there?......we had something similar.....Dave said it might be a hydraulic lifter....turned out to be just that. :D
Return to “Jabiru Engines”
