Morning all
Recently I realised that my traditional values I used when determining fuel remaining using the inspection windows was different when viewed on ground versus in the air (in straight and level flight, versus parked on level ground). In my last few flights I have amended my figures as follows:
• Full tank = 135L … set EFIS to 135L if tanks totally full when on flat ground - else less
• Fuel when on Ground - 55L remain when both windows at just 100% of window
• Fuel when on Ground - 25L remain when both windows at 50%
• Fuel when on Ground - 15L remain when both windows at 30%
• Fuel when in Air - 70L remain when both windows at 100% of window
• Fuel when in Air - 40L remain when both windows at 50%
• Fuel when in Air - 30L remain when both windows at 30%
• If Fuel light flashes for first time (10L remain), 24 min MAX = 40nm
• If Fuel light comes on steady (6.5L remain), 15 min MAX = 25nm
Sound about right? ... in my J430 it seems that there is a 15L discrepancy with how you view it.
Shaun
Fuel Management
- Straight and Level
- Has thanked: 113 times
- Been thanked: 153 times
Fuel Management
- Fower Tousand
- Has thanked: 79 times
- Been thanked: 17 times
Re: Fuel Management
Hallo Shaun
Ja these Jabies sure have a personality of their own. Best to get to know your plane well. Attached a plague that seems to be a one size fits all with some margin. Stick it next to your glass tube indicator and adapt, if necessary, to reflect your requirement.
Groetnis
Francois Gouws
Francois Gouws
