Noisy radio
antonvalks
Finals (unmanned)
Has thanked: 11 times
Been thanked: 8 times
Noisy radio
Unread post by antonvalks »
I am one of those pilots who always seem unable to properly set or adjust the radio to have good comms. :oops: :oops: On the ground, engine off, 5/5 comms. Engine on, I immediately have a noisy radio and struggle to communicate both inside the aircraft and with tower or other traffic.
I found this on the internet http://www.jabiru430.com/Radio_noise.html which would indicate it is a common problem with the Microair radio and/or installation.
Can someone please explain how to go about setting the radio up. I just want to make sure it is not my stupidity that causes the radio noise. I have the volume and squelch knob on the radio as well as a seperate one for the internal comms.
Willie
Closest Airfield: Hippo Pools
Has thanked: 4 times
Been thanked: 4 times
Re: Noisy radio
Unread post by Willie »
Hi
Do a test. Disconnect your voltage regulator an fly without it and the test your radio. Replace if needed.
Willie
ZS-UJC Hatz Bi-plane
ZS-UGS Evans VP 2
KR2 ZS-UNC
KR2 ZS- UUJ
Jabiru J400 ZU-VHB
Zenith 601 XL ZU-DVN
rainier
Has thanked: 67 times
Been thanked: 676 times
Re: Noisy radio
Unread post by rainier »
One of our customers who works with a lot of Jabiru aircraft installs an MGL Avioguard to supply the radio. This device takes whatever power you throw at it, no matter how bad, and produces nice clean DC at 13.2V (even if the input voltage is less).
This sorts out trouble with any radio that is sensitive to electrical noise on its supply.
Rainier
antonvalks wrote:I am one of those pilots who always seem unable to properly set or adjust the radio to have good comms. :oops: :oops: On the ground, engine off, 5/5 comms. Engine on, I immediately have a noisy radio and struggle to communicate both inside the aircraft and with tower or other traffic.
Has thanked: 1055 times
Been thanked: 895 times
Re: Noisy radio
Unread post by V5 - LEO »
[quote="rainier"]One of our customers who works with a lot of Jabiru aircraft installs an MGL Avioguard to supply the radio. This device takes whatever power you throw at it, no matter how bad, and produces nice clean DC at 13.2V (even if the input voltage is less).
Rainier
....can you use it with all / most radios Rainier?
zuepc
Closest Airfield: FASY
Noisy radio
Unread post by zuepc »
Ensure that the radio screws home flush with the actual mounting. In my case the radio was 4mm short of home because the actual panel was not cut properly to allow this!
flatprop
Closest Airfield: Morningstar
Has thanked: 1 time
Re: Noisy radio
Unread post by flatprop »
Hi used to have endless proplems with a MGL V6 radio that was so bad with interference in flight that normal communications was very difficult. As with the OP, it was 5/5 on the ground with engine and other electronic off.
Discussed with Rainier from MGL and he queried two things:
1. If I had any EFIS with screen (I did have the MGL Voyager system)
2. The distance of the antenna from the MGL EFIS screen.
Long story short, my antenna was too close to the EFIS screen (+/- 2m) and that caused the interference.
I relocated the antenna to the rear empenage (instead of above the cockpit) and problem sorted 100%.
To test, go fly and switch off your EFIS in flight, if comms improve your antenna is too close to the EFIS screen.
Pm me if you want to chat.
Gustav
Gustav Jansen
namjab
Closest Airfield: FYWE
Re: Noisy radio
Unread post by namjab »
Good morning everyone. I also have radio noise, but it is only when you ptt and testing a bit seems to be only when at full rpm.
It is a massively loud static noise, ear killing in fact only when talking to general traffic or towers. No noise on ground, no noise during finals where rpms are lower etc and also clear intercom regardless of rpm. It is only during ptt. I have the micro air and garmin setup with separate intercom. Garmin is used as primary, but even switching to micro air results in this same transmit noise.
I have switched off the efis in flight, no difference. Only slowing down engine seems to work at this stage. Traffic/tower have never complained about transmissions, i expect they are clear, but my ears don't agree.
Has anyone perhaps had similar issues that were resolved?
Thanks and have a great day
J430
Closest Airfield: Australia
Re: Noisy radio
Unread post by J430 »
Is this a newly developed issue or has it always been there?
Also, can you check by switching off each mag/coil to see if they are both noisy?
ZuluBen
Has thanked: 32 times
Been thanked: 16 times
Re: Noisy radio
Unread post by ZuluBen »
Just make sure that you have NO usb devices in the plane.
Not even a Powerbank...
Creates havoc on an AM radio :shock:
namjab
Re: Noisy radio
The noise has always been there. Will give the mag thing a go and let know.
I do not have any USB gadgets at all.
Marius Schrenk
Has thanked: 75 times
Been thanked: 58 times
Re: Noisy radio
We have had a similar thread long ago searched for it. From what I can remember the grounding of the engine was the reason :? the thick open wire at the starter corroded on the lug. :idea:
Pete
Has thanked: 295 times
Been thanked: 170 times
Re: Noisy radio
Unread post by Pete »
The correct grounding/ earthing is often overlooked, here is a great video on the basics of grounding comms in an aircraft to reduce radio noise.
https://www.youtube.com/watch?v=J08_p4O ... e=youtu.be
