ZU-MER AKA ZOOMER CAME HOME
Jan
Closest Airfield: MOSSELBAAI
Has thanked: 95 times
Been thanked: 159 times
Re: ZU-MER AKA ZOOMER CAME HOME
Unread post by Jan »
Thank you guys :wink:
Flying is about discipline!
AP325
Jan
It feels like years ago but in April 2019 I took Zumer to Piet Retief Mondi, slept over there and went to the EAA convention with Johan, a builder at Piet Retief Mondi.
AP325
Jan
Somewhere in July 2019 all my old precision flying friends were busy practicing for an ANR event. You get a map with a corridor marked out. You have to fly inside this corridor using basic equipment as in a compass and a stopwatch. All aircraft flies at a speed of 80 Kts. This is the only time that I wished for an slower aircraft. Below is the map after I have prepared it. The entry gate is top right where the time 12:15 is written in.
Below is may track flown - most of the time with full flaps. Old habits die hard and I instinctively went PAST some checkpoints and thereby busted the corridor. One is allowed to turn short of the points in order to stay within the corridor.
Believe me it is 20 minutes of intense concentration.
AP325
Jan
As time went on I have realized that at some stage I will have to repaint Zumer as the 10 plus years and normal use has taken it's toll. One take off a panel and where the skins overlapped, one could see the surface corrosion. Luckily only surface corrosion. I also had a few paint bubbles appearing in various places. Like the picture below that was taken of a wing skin. It is small but I did not like it.
And underneath on the flaps and ailerons where surface corrosion has been removed but not painted nicely.
I started fixing a few things like the rudder bottom, the canopy fiberglass in front of the plexi glass and other small items. This was done as part of the preparation for the complete repaint.
One item was the nose wheel spat. A bit of glass work, fill in, sand and one coat of paint for the time being.
AP325
Jan
Then I have decided to also redo the bottom intersection fairings. Stripped the paint off, bonded on the new ones. Then you have to split it and do a lot of fiberglass, sanding and filling.
And more fiberglass work and filling
Almost there :)
AP325
Has thanked: 870 times
Been thanked: 590 times
Unread post by Mrb13676 »
Jan wrote: Thu Jul 30, 2020 7:03 pm Somewhere in July 2019 all my old precision flying friends were busy practicing for an ANR event. You get a map with a corridor marked out. You have to fly inside this corridor using basic equipment as in a compass and a stopwatch. All aircraft flies at a speed of 80 Kts. This is the only time that I wished for an slower aircraft. Below is the map after I have prepared it. The entry gate is top right where the time 12:15 is written in.
Would be great to see you back at ANR events Jan! You missed one two weeks ago... ZOOMER looks like she'd be great for Speed Rallies too!
Mike Blackburn
ZU-IBM - Sling4 Turbo s/n 009 “Miss Daisy”
Jan
I am planning to be at the Secunda event Mike.
These users thanked the author Jan for the post:
AP325
Jan
Middle of March this year came the call that there is an opening at Aero Colour Lanseria. I ferried over to Lanseria and removed all flight control surfaces and everything else needed to prep it for painting.
Then primed
Then disaster struck when Alfred had to close his shop for LOCKDOWN LEVEL 5
AP325
Jan
Then finally after about three months ZOOMER came home.
Back home at Coves
These users thanked the author Jan for the post (total 3):
Ray WRogerPete
AP325
Had a look at her on the line at Secunda today - looks really great! Sorry I missed you to say hello....
Mike Blackburn
Jan
Thank you Mike - we all just too busy :D
AP325
KEO
Has thanked: 41 times
Been thanked: 28 times
Unread post by KEO »
Zu-MER looks great Jan!! Her stripes down the side reminds me of mine :D
Brett Williams
Whisper X-350 ZU-TCC
Jan
Thank you for the compliment Brett :D
AP325
Horace Blok
Closest Airfield: FAMO
Has thanked: 277 times
Been thanked: 110 times
Unread post by Horace Blok »
One really beautifully restored RV. Nice one Jan.
These users thanked the author Horace Blok for the post:
Jan
Hartog
Jan
I realize that I did not post on my lockdown project here. During lockdown I have designed nav/strobe/landing light modules specifically for RV wingtip. Zumer got the first two lights installed.
Below is a cad render of the module.
And as installed in Zumer.
And below a test - the far end down the road is about 300 meters away :D
PJL
AP325
