premature engine failure at 400 hrs
foxdog
Closest Airfield: Margate
Has thanked: 1 time
Been thanked: 8 times
Unread post by foxdog »
Hi Guys,
I was very disappointed with the premature engine failure of my Jabiru SP 120 on 01 07 2018 .
The engine was well cared for and operated correctly .
How i got away with my life and not scratching the aircraft is another story.
The failure was caused by an exhaust valve head breaking off and smashing a hole through the piston on No 3.
This was on a flight with everything in the green as it has always been.
Would you think this was just bad luck.
What precautions are there to stop this sort of failure.
Regards,
Foxdog
Has thanked: 920 times
Been thanked: 758 times
Re: premature engine failure at 400 hrs
Unread post by V5 - LEO »
....was it the Jabiru engine?
Marius Schrenk
Has thanked: 79 times
Been thanked: 58 times
V5 - LEO wrote: Tue Sep 18, 2018 4:39 pm ....was it the Jabiru engine?
How many lycoming/conti engines has had valve problems ??
Has thanked: 146 times
Been thanked: 1662 times
Unread post by cage »
foxdog wrote: Tue Sep 18, 2018 4:27 pm ...
Isn't every engine failure premature?
Some may say that on a Jabi it is actually a feature ;)
KIDDING
foxdog
Has thanked: 1 time
Hi Cage,
Yes the 2.2 85 hp Jab motor
foxdog
Has thanked: 1 time
Hi Marius,
Can you answer your question is it many or not
Foxdog
Marius Schrenk wrote: Tue Sep 18, 2018 6:01 pm
....lots, all engines are prone to a breakdown, it is mechanical after all - just seems that the Jab engines get more publicity on it :D
Flooi
Closest Airfield: Fahg
Has thanked: 103 times
Been thanked: 57 times
Unread post by Flooi »
Pity.... otherwise a great aircraft...
Flooi
Foxdog. Any news? What was cause?
Pray tell......
IWG
Priming
Been thanked: 1 time
Unread post by IWG »
Hi Foxdog,
Was the remaining valve stem bent or was it straight ?
This is an important indicator as to was the valve stuck open and hit by the piston,
or did the valve head drop and was then hit by the piston.
IWG
Flooi
IWG wrote: Hi Foxdog,
IWG
Very inquisitive as well.......
foxdog
Has thanked: 1 time
Hi Flooi and IWG,
I will get back to you mid month,
Foxdog
Shaunus
Airborne from Unmanned field
Closest Airfield: Morningstar
Has thanked: 91 times
Been thanked: 109 times
Unread post by Shaunus »
Am also interested on your forced lob story, sounds like you did an excellent job!
Flooi
I've been keeping an eye on Jabi issues for about ten years or so. My Jabi's have never
ever given an ounce of problems..... been cared for by Legair in Springs. I have noticed
some interesting stats though..... Avgas diet is better- especially if you fly little. Secondly,
engines that are run hard - 3000rpm cruise, seem to last longer. Lastly- If run too hot,
even for short periods- it WILL complain. It seems they need more TLC, but consider-
What can you buy for such competitive prices that can do so much? And I've got some
hours on plenty LSA....
Closest Airfield: FAPX
Has thanked: 840 times
Been thanked: 1771 times
Unread post by Chalkie »
Maybe some metallurgist can comment here...
As far as I know, all valves are made from two bits of metal, the valve stem and head are then friction welded together. IE the two parts forced together and spun to generate enough heat to melt the metal in the area of the joint. This will explain why occasionally an engine 'drops a valve.'
This could be for a number of reasons, such as a valve stuck open which the piston then hits. Or a failed valve spring allowing the collets and 'keeper' (Spring retainer) being dislodged, or the weld simply failing, etc.
Jabi use automotive parts, I wonder if the valves are made as described above, or not?
Pray, tell me Guru. What is the secret to eternal peace and contentment?
Never argue with an idiot.
OH, but I disagree!
Yes. You are right.
I would rather have scientific questions that cannot be answered; than answers that cannot be questioned.
Return to “Jabiru Engines”
