premature engine failure at 400 hrs
IWG
Priming
Been thanked: 1 time
Re: premature engine failure at 400 hrs
Unread post by IWG »
Hi Foxdog
Seeing that you are also a Mogas friend, you have the advantage of beeing able to use
part synthetic oil.
This reduces carbon buildup drastically and you will be surprised how clean the plugs stay.
I have done so for the last 220 hours and even the valve heads show almost zero buildup.
Before changing to Mogas the Aeroshell 100 in my engine turned blackish grey in 10 hours,
nowadays the oil looks almost new at the yearly oil change and I have had no more rough
idling or hiccups
IWG
Flooi
Closest Airfield: Fahg
Has thanked: 103 times
Been thanked: 57 times
Unread post by Flooi »
IWG wrote: Mon Jan 14, 2019 1:38 pm Hi Foxdog
part synthetic oil.
idling or hiccups
IWG
This is most informative.... how long can u store it? If one flies little, the mogas in tanks will
lose octane??? 😳
foxdog
Closest Airfield: Margate
Has thanked: 1 time
Been thanked: 7 times
Unread post by foxdog »
Hi IWG,
What is the oil that I should use that is part synthetic,
Regards Foxdog
IWG
Priming
Hi Foxdog,
If you use Avgas as an occasional backup only, you can run on Shell HX7 (10W-40).
When I use no Avgas at all, I found Shell HX8 to run even cleaner.
The other Part Synthetic/ Full Synthetic oils probably work as well, the Jabis are after the "40" viscosity.
IWG
Has thanked: 62 times
Been thanked: 1053 times
Unread post by heisan »
IWG wrote: Tue Jan 15, 2019 10:32 amIf you use Avgas as an occasional backup only, you can run on Shell HX7 (10W-40).
I would be very wary of using non-approved engine oils. API/SN is not recommended for air cooled engines...
IWG
Priming
Good point Heisan,
I have been pursuing this subject since 2007 and with the help of various oil experts
have made a list of lubricants suitable for applications under extreme conditions,
one was to operate a Cheetah with the J2200 engine in RiYadh, Saudi Arabia.
The final conclusion was, the 10W-40 SN type oil exceeds all requirements for the J2200.
It is however not suitable for many motorcycles aswell as Rotax 912/914 engines, as these
have gearboxes and clutches lubricated by the engine oil.
IWG
Return to “Jabiru Engines”
