Not a box Build!
Tomcat1
Closest Airfield: Silverton
Has thanked: 47 times
Been thanked: 207 times
Re: Not a box Build!
Unread post by Tomcat1 »
And you didn't even show us the rest of the build #-o :roll: [-( ...I'll check the vids when I get home, can't wait and congrats on the maiden Chris :wink: =D> =D> =D> =D>
sybrands
Closest Airfield: Jailbirds
Has thanked: 2 times
Been thanked: 16 times
Unread post by sybrands »
Superb my friend, really a great finish to a awesome project. Now PLEASE go for REAL ENGINE ON THE NEXT ONE....please? Well done on the landing, but I believe you stuffed up on all the others...?
I run on diesel fumes..
Theuns v V
Has thanked: 19 times
Been thanked: 551 times
Unread post by Theuns v V »
Beautifull, nice scale speed and slow landing :D
what electric setup? I need to look at something for my 1/7 spitty
Whizza_Flyer2
Taxiing
Closest Airfield: Warthogs
Has thanked: 1 time
Unread post by Whizza_Flyer2 »
Wonderful flyer Chris.
Post pics once you’ve painted it.
Bleriot
Been thanked: 238 times
Unread post by Bleriot »
Hi Whizza
No rush to paint yet, It was more of a project to see how the larger prop would work on the airframe and very pleased with the results.
It inspired me to try the ME 109 as I was not happy with the power I was getting as it seemed that it needed a larger prop than the 16 x10 as I was only getting 1000 watts. The airframe is also very heavy once finished and needed around 200 grams nose weight. Glad to report that it actually flies very well, needed quit a bit of aileron trim due to that sag in the top sheeting but other than that it is fine. Good duration and nice scale performance and looks great in the air.
Large props are the way to go on scale aircraft!
Bleriot
So after a year the Spitfire is going to be painted! Byron has offered to paint the airframe as he wants to try a few things with the finish. I had to do some of the things that are a real pain when building a Spitfire and that is the radiators and the cannon. I make the cannon from balsa and also have them removable which complicates things but you cannot move the wing without knocking them off. Mounting the cannon is a pain as it is very hard to get them straight so I decided to make a jig to help mounting them. This is what I did:
Bleriot
Byron has started adding some detail to the wing which looks very good. Byron has had to go back to work so progress will slow down.
These users thanked the author Bleriot for the post (total 2):
SNIPERinversion
Theuns v V
looks great. ok now give me tht wing so I can make a mold of it much easier to then make more later :wink:
Bleriot
Byron did manage to get some more work done, it is really starting to look stunning. Should be very nice oce painted and all the detail showing.
No Theuns, this is a flying Spitfire, you have seen how well it flies.
These users thanked the author Bleriot for the post:
Peter Connan
sybrands
Chris/Byron, this is a stunning example of top class scratch building! Well done, gonna be a real show-stopper when all painted and dollied up.
Bleriot
Sybrand, I am getting concerned, Cabin fever is making you quite user friendly. Not often that we get nice comments from you.
sybrands
Chris, Byron is doing this stunning work, so the compliments are aimed at him....but I will wait with the 'biting' till after I collect the cyano...but it is pretty as hell!!!
Bleriot
Byron had some time and some help so some colours were sprayed. If you have never done this before you will not understand the amount of work that it takes to mask the airframe for painting. Griffin has seen how to wear a face mask as demonstrated recently by a senior official on TV!
These users thanked the author Bleriot for the post (total 3):
inversionWingsandallPeter Connan
Theuns v V
love it =D> =D>
sybrands
So the youngest Freeman is now qualified to become No 1.....
Return to “General Model Aircraft Chatter”
