When nature calls?...
John Hilton
Mags On
Been liked: 11 times
Re: When nature calls?...
Unread post by John Hilton » Thu Jan 10, 2019 10:09 pm
Thanks for all of the insightful replies everyone, there seems to be multiple solutions - simplest of which seems to be the technical stop.
I will see about acquiring some of those pee wee bags, those could help in an absolutely desperate situation.
Thanks again,
John
Sceptic
Helicopter getting close
Closest Airfield: Port Elizabeth
Unread post by Sceptic » Fri Jan 11, 2019 10:05 am
BONNIE MAD
Unread post by BONNIE MAD » Fri Jan 11, 2019 12:59 pm
Its quite simply easier to <<moderated - language>> in your pants than tangle with African countries and their clearances
MEN WERE MEANT TO RIDE WITH CLOUDS BETWEEN THEIR KNEES
Jean Crous
Closest Airfield: FASX
Has liked: 126 times
Been liked: 65 times
Unread post by Jean Crous » Fri Jan 11, 2019 1:12 pm
chrisbe20 wrote:
Wed Jan 09, 2019 10:39 pm
The Hun wrote:
Wed Jan 09, 2019 3:53 pm
First thing I installed in my Cubby, was a funnel and a pipe leading outside
Heard of a guy back in the day of Rhodesia, he had a funnel fitted into his PA235 with one of those old venturi gyro systems still seen on some old 172's due to a bad bladder...apparently on the first use it sucked his job into it so bad he made an emergency landing. :shock:
A battered, tattered todger comes to mind :shock: :shock: Methinks a good clean HTH bottle is the way to go, cheap and effective.
Jean.
Cubby Aircraft Factory
Cell : 072 6716 240
jaggedassasins
Unread post by jaggedassasins » Fri Jan 11, 2019 7:35 pm
This. If you don't have a landing permit for the country you land in, the chances of being arrested tend to increase exponentially.
Rotor kop
Closest Airfield: OR Thambo
Has liked: 109 times
Been liked: 15 times
Unread post by Rotor kop » Fri Jan 11, 2019 10:04 pm
A 2L milk bottle or oros bottle works well.
Has liked: 12 times
Been liked: 239 times
Unread post by cage » Fri Jan 11, 2019 10:09 pm
Or just don't have a prostate the size of a melon?
CWS
Closest Airfield: Morningstar
Unread post by CWS » Sat Jan 12, 2019 4:34 pm
:D
:D :D Technically your prostate had nothing to do with how big a pee you can make. It only holds—- oh damn this is a family show you may have to look it up😂
Rotorblade
Unread post by Rotorblade » Sat Jan 12, 2019 7:12 pm
Interesting topic. Allegedly Heli drivers never have this problem: they simply whip it out, unroll it halfway and then let it hang out in the breeze. I am properly jealous. :D
But if not a Heli pilot, the chem bag proposed in a gliding context seems an excellent solution. Where may mere mortals obtain those?
Has liked: 12 times
Unread post by cage » Sat Jan 12, 2019 7:25 pm
The problem with that method is getting the tackle wrapped around the tail rotor :twisted:
bear
Steep Turn Right
Unread post by bear » Tue Jan 15, 2019 2:26 pm
No idea on a solution for a number 2, but a browse through the fruit juices at almost any cafe will reveal some 500ml juices in a plastic bottle, with a large enough spout to make aiming easier.
Givane O
Closest Airfield: Jandakot
Unread post by Givane O » Wed Jan 16, 2019 5:16 am
This doesn't take up much space when empty, even softness can use it.
IMG_20190116_111058.jpg[/attachm ent][attachment=0]IMG_20190116_111139.jpg
Givane Oosthuizen
"The greater difficulty, the more glory in surmounting it. Skillful pilots gain their reputation from storms and tempests"
"The only mystery in life is why the kamikaze pilots wore helmets"
Has liked: 108 times
Been liked: 101 times
Unread post by richard C » Wed Jan 16, 2019 10:41 am
Yeah yeah. That would be your HF antenna, methinks.
Grant all equity and dignity.
Jayson v Schalkwyk
Closest Airfield: Himeville
Been liked: 12 times
Unread post by Jayson v Schalkwyk » Thu Jan 17, 2019 10:01 am
"wee Jon" are available from any good pilot shop. Or, a Staysoft fabric softener bottle "or similar" would work.
Jayson van Schalkwyk
Owen
Unread post by Owen » Sat Feb 02, 2019 4:29 pm
The best is an HTH chlorine container, for #1 or #2 or both or airsickness
