Avgas Quality
Andrew Fletcher
Avionics Master On
Avgas Quality
Unread post by Andrew Fletcher » Thu Jan 10, 2019 6:13 pm
Just a Heads-Up
SACAA seems to be concerned about possible contaminated avgas at some airfields.
A Notam was published very recently regarding this.
It requests pilots not to use fuel that seems suspect in terms "smell and looks", and to give a sample to CAA if suspect fuel is encountered.
Rotor kop
Closest Airfield: OR Thambo
Has liked: 137 times
Been liked: 16 times
Re: Avgas Quality
Unread post by Rotor kop » Thu Jan 10, 2019 7:33 pm
Would love to know who supplier is for these suspected fields?
Has liked: 63 times
Been liked: 55 times
Re: Avgas Quality
Unread post by V5 - LEO » Thu Jan 10, 2019 7:57 pm
....how can only one suplliers' avgas be suspect, the source is the same - looks like a go at certain suppliers to worm them out - ja boet it never rains.....
Has liked: 345 times
Been liked: 140 times
Re: Avgas Quality
Unread post by Ray W » Thu Jan 10, 2019 10:49 pm
The language used in this notam is, in my opinion, not up to standard. I suspect this may be fake but I'm not sure.
Lood
Re: Avgas Quality
Unread post by Lood » Fri Jan 11, 2019 5:28 am
Ray, the language used is probably quite up to standard - African standard ... #-o
Segg
Has liked: 79 times
Been liked: 24 times
Re: Avgas Quality
Unread post by Segg » Fri Jan 11, 2019 7:33 am
If its 95 (green) mixed with 100LL (blue) you'll get cyan - not the easiest to detect
If its 93 (yellow) mixed with 100LL (blue) you'll get green
Don't know how else to detect if the fuel is cut apart from testing the batch in a lab, and to my knowledge our fuels don't have ethanol so the water test is also useless
Has liked: 28 times
Been liked: 142 times
Re: Avgas Quality
Unread post by heisan » Fri Jan 11, 2019 9:57 am
Just smell it...
Segg
Has liked: 79 times
Re: Avgas Quality
Unread post by Segg » Fri Jan 11, 2019 10:37 am
Just smell it...
What does one look for? A stronger smell?
Has liked: 28 times
Re: Avgas Quality
Unread post by heisan » Fri Jan 11, 2019 12:36 pm
Difficult to explain - but the smell is definitely distinctive. Smell some samples yourself and you will quickly notice the difference.
Has liked: 204 times
Been liked: 77 times
Re: Avgas Quality
Unread post by Fransw » Fri Jan 11, 2019 1:14 pm
Agree, the supplier needs to answer some questions here!
