Nieuport 24
Airdrome Aeroplanes - WW1 Replicas
Theuns v V
Has thanked: 19 times
Been thanked: 545 times
Nieuport 24
Unread post by Theuns v V »
I am in the very kucky position of having been given a 1/4 built kit of a full size Aerodrome Nieuport 24.
Now this will be a long term project as with 2 kids at school funds for this will be extremely limited at the moment.
I have built a full size Super cub from plans only so fo me building a kit will be a treat :)
I am hoping to collect next week and will then plan my next move on how to tackle this project, stay tuned
Theuns
Has thanked: 1067 times
Been thanked: 5073 times
Re: Nieuport 24
Theuns v V wrote: Sun Jan 20, 2019 6:11 am I am in the very kucky position of having been given a 1/4 built kit of a full size Aerodrome Nieuport 24.
Theuns
Are you sure its 1/4 scale .. that would put it in R/C territory ?
87Juliet
Has thanked: 331 times
Been thanked: 303 times
Re: Nieuport 24
Unread post by 87Juliet »
Uncle Bear, I think he meant it’s 1/4 complete or 25% built
Jacques Taljard: Zero-Ate-Two Niner-4-Wun Seven-Zero-Sex-Too
Theuns v V
Re: Nieuport 24
:) full.size Bruce, its 1/4 built.....with 95% to go still :lol:
Re: Nieuport 24
Theuns v V wrote: Sun Jan 20, 2019 9:30 am :) full.size Bruce, its 1/4 built.....with 95% to go still :lol:
Glad to hear its full size Theuns ...otherwise you would have had to get into some serious dieting :lol:
Theuns v V
Re: Nieuport 24
Bruce I am so maargat these days if I lift my arms I can fall through my own a$$ :wink:
Theuns v V
Re: Nieuport 24
with the help of Peter we collected the kit today from Raymond :D :D Tahk you both =D> =D>
It will be alot easier build than the scratchbuilt L-18 I did some time ago.
Now the long road begins :wink:
T
Theuns v V
Re: Nieuport 24
Having scratch built a full size replica before I know how much time it takes to do so and the effort that goes into it so what I will do is the complete and cover the rudder to final colour, this will then be placed where I can see it every day to enspire me to put the time in :)
Theuns v V
Re: Nieuport 24
Rudder hindges linned up wit old school way. riveted in and after a cleaning the frame is ready to cover :)
I will have to get a pneumatic rivet puller, the few rivets I put in the hindges now took every bit of power I could muster :roll:
Theuns v V
Re: Nieuport 24
I wanted to try loomstate fabric on full size, had good results on models with it to I covered thr rudder.
The fabric does not shrink as well as pollifiber or ceconite. Even applied tuaght and shrunk to 350degF it feels more " stretchy"
I brussued on a coat of dope and this morning saw the bumps in the fabric, the dope goes through the loomstate allot easier than I am use to with the certified fabrics.
I tried heat to melt them away but no use, I also know there is no way sanding them away so I decided to strip off the fabric.
What concerbed me is how fairly easy the fabric stripped off the frame, even though I used certified glue onto the alluminium frame....dont like this atall :(
So, I might have to stick to a certified fabric, have sewn emveloupes made up for the frames and see if that works better.
T
Trevor Duane
Closest Airfield: KIZAD
Has thanked: 147 times
Been thanked: 311 times
Re: Nieuport 24
Unread post by Trevor Duane »
Theuns, did the glue bond well with the tube and separate from the fabric or did the fabric and glue separate from the tube ?
What is the price comparison between the loomstate and certified materials ?
Lastly what weight is the loomstate equivalent to 1.9 oz or 2.7Oz ?
I hope you have found a solution in the time between posts on this project :)
Theuns v V
Re: Nieuport 24
I cant recall the exact weight of the loomstate but t is a little lighter than the standard 2.7 Oz certified medium fabric.
As for comming off the frame, it did not fail or pull loose by itself, I was just not happy with the bond on the small trailing edge tube and will now rather have a sewn seam on the trailing edges.
I just covered a dechthlon last week with same size steel tubes but I used pollifiber and it stuck down like I know it to :wink:
T
Theuns v V
Re: Nieuport 24
Ceconite and dope this time, results the way I want them :)
T
These users thanked the author Theuns v V for the post (total 2):
Ray WRudiGreyling
Trevor Duane
Re: Nieuport 24
Lovely T just lovely.
Does this mean Loomstate is a no go ?
And Is this all you have done ? 8-[
Theuns v V
Re: Nieuport 24
I did not have success with the loomstate on full size, on models works fine for me.
I have worked on the rudder only this weekend, to busy with other projects for now. Want to get it painted up so I can maybe get inspired to do more work. :wink:
Return to “Airdrome Aeroplanes”
