FEBRUARY 2019 CONTACT!
Experimental Aircraft Association of South Africa aims to assist its members with building, flying, and restoring non-type certified aircraft.
MaverickKevin
Rotating
Has thanked: 36 times
Been thanked: 25 times
Unread post by MaverickKevin »
Hello EAA'ers and Friends
The latest edition of CONTACT! can be found here :
http://eaa.org.za/wp-content/uploads/20 ... y_2019.pdf
If you have any aviation related content,please feel free to send it to info@eaa.org.za
The Editor
Remember- the mags are always hot, the oil cap is always loose ...
Aviate Navigate Communicate!
Return to “EAA of South Africa”
