This is nuts!!
Daimler
This is nuts!!
Unread post by Daimler » Wed Mar 06, 2019 11:28 am
Rotor kop
Closest Airfield: OR Thambo
Has liked: 113 times
Been liked: 15 times
Re: This is nuts!!
Unread post by Rotor kop » Wed Mar 06, 2019 2:49 pm
Why?
Firedog
Forgot to remove the chocks!
Closest Airfield: FAVG
Re: This is nuts!!
Unread post by Firedog » Thu Mar 07, 2019 7:38 pm
That pilot creates the impression that he is a bit of a show off - I don't doubt that he or his machine can "handle" that type of flying - to see his true capability will be when that single engine fails while he is busy with this sort of thing - not much of an escape route either about the way he approached the pick-up. Maybe I am just old school but a single engine chopper in mountains needs to be flown with care....
Barney
ZU-FDG Jabiru J430
Falafel
Power off Glide
Closest Airfield: FALA_LCY
Has liked: 35 times
Been liked: 57 times
Re: This is nuts!!
Unread post by Falafel » Fri Mar 08, 2019 10:48 am
I would also question what type of stress was put on the airframe?
Has liked: 12 times
Been liked: 258 times
Re: This is nuts!!
Unread post by cage » Fri Mar 08, 2019 10:57 am
I think you need to be careful reading too much into this.
The angle and the camera used exaggerates the perspective, it could well have been little more than a run of the mill torque turn - whether or not that is a smart thing to do in that situation can be debated.
Return to “Rotor Wing”
