Jasondn78
Closest Airfield: FAPE
Unread post by Jasondn78 » Sun Mar 10, 2019 12:27 pm
I know FR24 only reports ground speed, but considering the winds at the airport and the low altitude, I would the ground speed is very similar to actual airspeed. Close to 400kts at that low altitude is very fast. Could overspeed cause loss of control?
Slick
Flaps set for Take off
Has liked: 16 times
Unread post by Slick » Sun Mar 10, 2019 12:47 pm
I think you're correct. Aren't the 73's limited to 250KIAS below 10 000ft? Haven't worked it out but I doubt 250KIAS will equal 380kt GS at 8000ft. Maybe someone with a Wizz Wheel can work it out?
Has liked: 542 times
Been liked: 621 times
Unread post by jimdavis » Sun Mar 10, 2019 1:05 pm
250 KIAS at a density altitude of say 10 000' will give a TAS of 290 kts
henkhugo
Has liked: 42 times
Unread post by henkhugo » Sun Mar 10, 2019 1:05 pm
Accident Bulletin no. 2
Issued on march 10, 2019 at 01:46 PM
Ethiopian Airlines Group CEO deeply regrets the fatal accident involved on ET 302 /March 10 on a scheduled flight from Addis Ababa to Nairobi.
The group CEO who is at the accident scene right now regrets to confirm that there are no survivors.
He expresses his profound sympathy and condolences to the families and loved ones of passengers and crew who lost their lives in this tragic accident.
Henk
Has liked: 85 times
Been liked: 171 times
Unread post by GL » Sun Mar 10, 2019 1:12 pm
Judging from the size of the crater it augured in at great speed.
The essentials to happiness:
• someone to love,
• something to do,
• something to hope for
Guy Leitch
Spoke Eagle
Been liked: 26 times
Unread post by Spoke Eagle » Sun Mar 10, 2019 1:37 pm
In the last 15s they climbed nearly 2000'. Maybe trying to climb and reduce the speed because the idiot computer wouldnt slow down. Maybe the stabiizer failed then. Bless their souls.
Swartbok
Closest Airfield: Wonderboom
Has liked: 33 times
Been liked: 82 times
Unread post by Swartbok » Sun Mar 10, 2019 1:39 pm
Assuming Take off on 07R (the longest runway) max TOW could be 77500kgs with the prevailing conditions.
According to RET’s data, they were at 232kts at 400ft AGL.
They should have been at max 182 kts (V2+20)(let’s add a few knots for TAS), should have been no more than 200kts. And only at 400ft start to accelerate to flap up speed (221kts).
Why was the speed indicating so high?
737’s aren’t limited to 250 below 10 000ft unless a non-normal condition exists (ie. MEL requires it if window heat is inop)
The 250kt limit is an ATC/airspace limit.
Flying is like sex. I've never had all I wanted but occasionally I've had all I could stand.
Unread post by jimdavis » Sun Mar 10, 2019 1:43 pm
I see Sky News reported: The plane "had an unstable vertical speed" after take-off, according to the flight tracking website Flightradar24.
That doesn't sound good for Boeing if it is true.
Swartbok
Has liked: 33 times
Unread post by Swartbok » Sun Mar 10, 2019 1:46 pm
By my calculations the data shows V2+35kts at 300ft.
It should have been V2+20 until 400ft
Admittedly I have not corrected for high alt./high TAS I also dunno what speeds are shown in RET’s data(GS or???) but it probably still shouldn’t have indicated that high, or they were very naughty boys. Dunno
Spoke Eagle
Unread post by Spoke Eagle » Sun Mar 10, 2019 2:27 pm
What would fail first if you overspeed to much?
Burner
Closest Airfield: LIMB
Has liked: 17 times
Been liked: 134 times
Unread post by Burner » Sun Mar 10, 2019 2:33 pm
The local news in Italy is mentioning 8 Italian pax on board, with another total of 35 different nationalities. No news yet if any South African passengers were on board. Terrible...
Has liked: 85 times
Unread post by GL » Sun Mar 10, 2019 2:42 pm
One can only hope that the FDR and CVR are recoverable. But judging from the crater that may need a miracle.
• someone to love,
• something to do,
Guy Leitch
Swartbok
Has liked: 33 times
Unread post by Swartbok » Sun Mar 10, 2019 2:45 pm
The Chief Pilot’s humour. :lol: :lol:
Probably the empennage or wings, if it’s clean, I guess. (Operative words being “too much’)
At 380kts I seriously doubt anything should break off.
Burner
Has liked: 17 times
Unread post by Burner » Sun Mar 10, 2019 2:50 pm
I see its previous 4 flights were all between OR Tambo and Addis... depending on what actually happened, sobering to think that whatever happened could have gone on just after take off above Joburg.
Hits close to home considering how many South Africans use Ethiopian.
Coldsteel
Mags Dead Cut
Closest Airfield: ___
Has liked: 11 times
Unread post by Coldsteel » Sun Mar 10, 2019 3:04 pm
Plots from FR24 data.
