electrical problem SP120
foxdog
Avionics Master On
Closest Airfield: Margate
Unread post by foxdog » Sun Mar 17, 2019 8:54 am
Hi Guys,
I have an electrical problem with the 10 amp fuse blowing for the instrument panel.
This could be related to the VDO oil temp gauge that returns back to zero then back to normal during flight.
I have changed both the oil temp sender as well as gauge and problem still exists.
Can anyone suggest where i could start to look for any obvious clue .
Regards,
Foxdog
Flooi
Closest Airfield: FAHG
Re: electrical problem SP120
Unread post by Flooi » Sun Mar 17, 2019 1:17 pm
Have you tried replacing the wire and connection plugs. That is about all
that’s left that could go wrong.....
Hennie
These users liked the author Flooi for the post:
ZuluBen
Hennie van Zyl
