SAA Fleet Renewal
- Aircraft in Hangar
- Closest Airfield: Wonderboom
- Has liked: 5 times
- Been liked: 0
SAA Fleet Renewal
With the rumours floating around that SAA has bought 2 x A350-900s, and an Airbus livery A330NEO seen at OR Tambo recently, perhaps we could discuss the future of SAA's long haul fleet renewal and how the plan to replace the ageing A340s? Any insight would be appreciated
- Last nights Garlic 'repeats' itself.
- Closest Airfield: FAPE
- Has liked: 27 times
- Been liked: 28 times
Re: SAA Fleet Renewal
As much as I'd like this to be true.
Is there any substance to this?
Is there any money for it?
How much longer to the A340's have?
- Has liked: 10 times
- Been liked: 52 times
Bought is a very specific term. I doubt they have bought them. Likely leased.sweeterz wrote: ↑Wed Mar 27, 2019 12:47 pmWith the rumours floating around that SAA has bought 2 x A350-900s, and an Airbus livery A330NEO seen at OR Tambo recently, perhaps we could discuss the future of SAA's long haul fleet renewal and how the plan to replace the ageing A340s? Any insight would be appreciated![]()
- Six Tousand
- Has liked: 411 times
- Been liked: 312 times
The reason the A330NEO was at ORTsweeterz wrote: ↑Wed Mar 27, 2019 12:47 pmWith the rumours floating around that SAA has bought 2 x A350-900s, and an Airbus livery A330NEO seen at OR Tambo recently, perhaps we could discuss the future of SAA's long haul fleet renewal and how the plan to replace the ageing A340s? Any insight would be appreciated![]()
https://www.avcom.co.za/phpBB3/viewtopi ... 0#p2028604
- Fife Thousand feet
- Closest Airfield: OMDB
- Has liked: 1 time
- Been liked: 19 times
Rumours of SAA leasing 2x A350-900 are very true. SAA wants to fly direct to JFK with these 2.
They are studying if they need the standard or ULR version to maintain a year around direct service.
Hannes Meyer
Standard or ULR makes no difference to SAA. They both have the same engine thrust with a marginal difference in MTOW. The ULR comes with greater fuel capacity (24,000L extra) which isn't necessary for JNB-JFK. The question will be how much of a weight penalty it'll have out of JNB. My estimation is that it'll lose maybe 5 to 10t in MTOW which is as good as you get!
- Has liked: 3 times
- Been liked: 10 times
I find this comment interesting about the A350 all of a sudden being suitable for SA- East coast USA routes considering your comments below made only few weeks ago on another forum:evanb wrote: ↑Sat Mar 30, 2019 3:51 pmStandard or ULR makes no difference to SAA. They both have the same engine thrust with a marginal difference in MTOW. The ULR comes with greater fuel capacity (24,000L extra) which isn't necessary for JNB-JFK. The question will be how much of a weight penalty it'll have out of JNB. My estimation is that it'll lose maybe 5 to 10t in MTOW which is as good as you get!
Did you perhaps forget when you wrote that comment that Delta actually operate A350’s or do you stand by your comment that only the B777-200LR is suitable for the SA-East coast USA routes?* DL are very established in South Africa and could easily add 3x/4x weekly seasonal service to CPT. I suspect they already would have if they thought the market where there. One of the challenges for them may have been the right aircraft. They would likely only start the route if they could do it non-stop from ATL and the only aircraft they have that could make it is the B777-200LR. However, it might be too much aircraft and too expensive to fly on the route relative to the yield they could achieve.
I do stand by it. The A350-900 is available in various TOW options, from 260t to 280t. Delta acquired the lowest TOW options in order to optimize their aircraft for slightly shorter missions, mostly northern US to Asia. This significantly reduces their range, but has some cost savings over the shorter routes they operate. The longest route the low TOW Delta A350s fly is ATL-ICN which is nearly 1,000nm shorter than ATL-CPT.FoxTROT wrote: ↑Sat Mar 30, 2019 9:21 pmDid you perhaps forget when you wrote that comment that Delta actually operate A350’s or do you stand by your comment that only the B777-200LR is suitable for the SA-East coast USA routes?* DL are very established in South Africa and could easily add 3x/4x weekly seasonal service to CPT. I suspect they already would have if they thought the market where there. One of the challenges for them may have been the right aircraft. They would likely only start the route if they could do it non-stop from ATL and the only aircraft they have that could make it is the B777-200LR. However, it might be too much aircraft and too expensive to fly on the route relative to the yield they could achieve.
SAA would likely be acquiring the 275t or 280t versions. While 15t doesn't sound like much, it's quite a lot when the OEW is about 140 to 145t.
- Has liked: 1 time
I hear from anther source SAA have been offered MSN 2 and 4. They currently being stored at BOD and LDE.
Wonder what price they been sold at being prototypes/test aircraft. How much work must go into such an aircraft to get in ready
again for airline operation.
Hannes Meyer
- Rotating
- Closest Airfield: OR Tambo Intl
- Has liked: 1 time
- Been liked: 9 times
So I assume SAA would be operating the A350/A330 as a common fleet.
Does that mean the blokes flying the A340 would be limited to quads only ?
- ATC Delay
- Closest Airfield: HONG KONG
- Has liked: 1 time
- Been liked: 16 times
Lufthansa flies A340/330/350 as common fleet (apparently). Might require approval from CAALongRangeCruise wrote: ↑Sun Mar 31, 2019 6:23 pmSo I assume SAA would be operating the A350/A330 as a common fleet.
B722, B744, A320, A332, A333, A342, A343, A346, Alo3, Oryx, King Air, Beech 1900, T6
- Closest Airfield: ORTIA
- Has liked: 0
- Been liked: 0
It does not mean anything. Perhaps the rumour should be confirmed first, before jumping the bandwagon.LongRangeCruise wrote: ↑Sun Mar 31, 2019 6:23 pmSo I assume SAA would be operating the A350/A330 as a common fleet.
Similar rumours have surfaced, more than once before. SAA operating some of EY 777's, just to mention one. Nothing came of that. I'll be more than a little surprised if anything comes from this one either.
- ATC Delay
- Has liked: 1 time
Ok some facts
The new fleet renewal for SAA was always going to be a challenge. Quads are finished. Twins are compromised.
Here are the performance penalties for the A350-900 with a MTOW of 275t out of JNB.
FAOR 03L: Wind 030/05, Q1025, Temp 25c, Packs Off, Rwy Dry. RTOW 261t. (14t penalty)
FAOR 21R: Wind 210/05, Q1025, Temp 25c, Pack Off, Rwy Dry. RTOW 256.9t. (18.1t penalty)
I doubt the B787 or B77X will fare much better. All modern twins take a big knock out of JNB. Which suits SAA best is the tough question. It’s these numbers which make JNB-JFK such a challenging sector. The rest are simple.
- Has liked: 0
- Been liked: 0
Using your current figures, the 77W has a RTOW of 321 049 kg, off 03LTrent772B wrote: ↑Sun Mar 31, 2019 7:22 pmOk some facts
SAA has seldom done what is right, when it came to aircraft selection. I very much doubt that it will be any different this time around, IF it has to happen.
- ATC Delay
- Has liked: 1 time
Which of two carries the most payload vs fuel burn?machdecimal83 wrote: ↑Sun Mar 31, 2019 7:38 pmUsing your current figures, the 77W has a RTOW of 321 049 kg, off 03LTrent772B wrote: ↑Sun Mar 31, 2019 7:22 pmOk some facts
