Pitts pilot lands propless plane..
Has liked: 175 times
Been liked: 66 times
Unread post by Fransw » Wed May 01, 2019 10:08 am
HJK 414
Closest Airfield: EHTW
Has liked: 45 times
Been liked: 258 times
Re: Pitts pilot lands propless plane..
Unread post by HJK 414 » Wed May 01, 2019 10:12 am
Oooooops
Quite a worry when your Prop decides to retire from active duty in mid flight ….. :wink:
JK
These users liked the author HJK 414 for the post:
Technocrat
Burner
Closest Airfield: LIMB
Has liked: 12 times
Been liked: 98 times
Unread post by Burner » Wed May 01, 2019 10:16 am
Definitely! Possibly a worse of a shock if the whole prop doesn't come off at once! The vibrations and forces associated with just losing one blade must be horrific!
I once had a prop deice failure in icing on one blade out of a four blade prop. Just the unbalance caused by unequal ice accretion, was startling!
Chuck
Closest Airfield: FLKK
Has liked: 37 times
Been liked: 17 times
Unread post by Chuck » Wed May 01, 2019 11:29 am
Precise proactive pilot input procedures prevented possible problems
These users liked the author Chuck for the post:
DonC
'What we find on internet, we readily believe, and what we ourselves find, we imagine others find also.'
Julius Ceasar, 44 BC
Your warning level: [1]
http://www.chickenwingscomics.com/comic ... cw0466.jpg
Has liked: 252 times
Been liked: 183 times
Unread post by Ugly Duckling » Wed May 01, 2019 10:18 pm
Spencer was due to attempt setting the world inverted spin record
https://www.facebook.com/48826748009/po ... 353558010/
Multirotordronepilot
Has liked: 38 times
Been liked: 55 times
Unread post by Multirotordronepilot » Thu May 02, 2019 6:35 am
That scenario will most likely see you loosing everything fwd of the firewall along with the broken blade.
Trevor
Defense Contractor/Test Pilot
Commercial pilot,Instructor
Responsible Person Aircraft
TopRC HawkerHunter
JetLegend ViperJet
BVM F80 ShootingStar
1/3 J3 Cub
ZS-VVR
