Glasair Crash - Wings Park - 1 May 2019
Has liked: 293 times
Been liked: 125 times
Re: Glasair Crash - Wings Park - 1 May 2019
Unread post by Ray W » Thu May 02, 2019 12:53 pm
Glad the folks are going to be OK - aeroplane not so good
These users liked the author Ray W for the post:
Piet propeller
antonvalks
Unread post by antonvalks » Thu May 02, 2019 1:51 pm
What a shame! :( Such a special aircraft! Speedy recovery to the crew.
Multirotordronepilot
Has liked: 38 times
Been liked: 55 times
Unread post by Multirotordronepilot » Thu May 02, 2019 2:16 pm
Thomas wrote:
Thu May 02, 2019 12:18 pm
Wow that seriously looks scary to see a fuselage just split apart so cleanly. As Volo mentioned where is the longitudinal strength? No longitudinal carbon fibre reinforcement? What if that came apart in severe turbulance? Would this mean the layout of the fibreglass was not done correctly?
I am not a specialist in fibreglass or strength of materials but this is worrying? Perhaps someone in the know could shed some light?
While I do not disagree with Volo or you that there could have been some longitudinal top hats or core sections in the laminate. There is nothing wrong with the design from a airworthiness point of view. Do so research into the aircrafts history and you will find it has more than proven itself as airworthy.
It is not easy to understand the loads at the point of impact by this could not have occurred due to turbulence which the aircraft should be operated in.
Additional strength could have presented use with a different wreckage but from an airworthiness perspective you need no longer be worried.
Aircraft built to survive a crash don't fly very well.
These users liked the author Multirotordronepilot for the post:
mnmodels
Trevor
Defense Contractor/Test Pilot
Commercial pilot,Instructor
Responsible Person Aircraft
TopRC HawkerHunter
JetLegend ViperJet
BVM F80 ShootingStar
1/3 J3 Cub
ZS-VVR
mnmodels
Closest Airfield: FAOH
Unread post by mnmodels » Thu May 02, 2019 2:23 pm
Very well said,
Composites are not alclad or 2024 material. It breaks like glass if the right forces are applied, even though they are 10 x stronger than metal....Aircraft are not design to fly after a crash....if the pilots wlaked away - thats good enough for me...
Rgds
These users liked the author mnmodels for the post (total 2):
BigglesSApropshaft
Morné Nortier
ZU-IPH CX150
ZS-EAE Project
ZS-MWC C150
ZU-IOY X350
Shaunus
Paying Landing Fees
Has liked: 10 times
Been liked: 12 times
Unread post by Shaunus » Thu May 02, 2019 6:29 pm
Was it on 09 ... the runway camber midway can easy catch the unaware... its like a black hole sucking you down to the bushes.
Sad to see, all the best to the pilot and pax for a speedy recovery.
Shaun
Rooster
Rolling from unmanned
Been liked: 10 times
Unread post by Rooster » Fri May 03, 2019 5:11 am
This comment is a misleading one in my opinion and may influence the speculation negatively.
Wings Park runways (although used at your own risk) are brilliant.
Reid
If a dog is grinning, it may not be happy!
Shaunus
Paying Landing Fees
Has liked: 10 times
Unread post by Shaunus » Fri May 03, 2019 8:04 am
Reid
Not meant to be at all Rooster. I have been to Wingspark a few times as I really enjoy the people and the field. And yes, the runways are brilliant. But a few of us (within my flying circles) have commented in the past about how the mid-way camber on 09 can potentially catch you out on take off. Its not an issue at all if you are aware, but if not you can easily find yourself drifting down to the bushes requiring positive left rudder to stay on track. I am amazed you don't find this as a strong potential point of speculation?
vlammie
Unread post by vlammie » Fri May 03, 2019 8:57 am
To me it look more like an aircraft that was airborne and then crashed than one that went off the runway? Any update on what happened? Speedy recovery to the occupants!
Has liked: 108 times
Been liked: 101 times
Unread post by richard C » Fri May 03, 2019 9:04 am
Looks like a cartwheel to me - the injuries sound right as well. Maybe a low-level wing drop and planting a wing tip ?
Grant all equity and dignity.
Has liked: 298 times
Been liked: 308 times
Unread post by jimdavis » Fri May 03, 2019 9:11 am
I understand that he did indeed lose directional control and tried to fly out of it before the aircraft was ready. It seems he stalled and dropped a wing. This is second hand info - but I believe it to be accurate.
I have not flown out of Wings Park, but I have indeed seen the slight camber. I must agree that if you have a twitchy aircraft on which you are not current, it could possibly add to your problems.
Out of interest, the heaviest bit of the aircraft will try to head down the camber. So if you have a nose wheel, the heaviest bit is at the front, and she will want to head down the camber. A taildragger will do the opposite - the tail will tend to move down the camber and the nose will point uphill.
These users liked the author jimdavis for the post (total 4):
Vaughan KDobbsDragonWingnut
MLyons
Been liked: 14 times
Unread post by MLyons » Fri May 03, 2019 9:14 am
Interesting Jim, thanks for the insight.
One learns little gems in between all the flack on this forum if one looks for them...…
These users liked the author MLyons for the post (total 4):
ACE MANAlan RobertsonDobbsWingnut
You toucha my stuff, I breaka you face.
Idiot in search of a village........never mind - found it!
Beech55
Unread post by Beech55 » Fri May 03, 2019 9:41 am
Beech55
Unread post by Beech55 » Fri May 03, 2019 9:42 am
It’s the same aircraft.
Has liked: 292 times
Been liked: 60 times
Unread post by ACE MAN » Fri May 03, 2019 9:49 am
WRT - that’s assuming the tailwheel is on the ground?
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
Shaunus
Paying Landing Fees
Has liked: 10 times
Unread post by Shaunus » Fri May 03, 2019 10:23 am
I would have agree with the tail wheel having to be on the ground, as my very first take off from Wingspark nearly ended up in a trip to the bushes in a taildragger. I had been offered my first flip in a Piper Cub after arriving in my Cubby, and was super excited and given control to do the takeoff in Cubby's bigger brother. I learnt a valuable lesson from the PIC that day as we started veering to the right, he said "If your plane is not going where you want it to, you stomp harder on the rudder pedals!" Being new to the plane, I was too gingerly on the rudder.
