Boeing 757 for FACT FAOR route?
Millibar
Unread post by Millibar » Fri May 03, 2019 7:39 am
Why was the 757 never used on this route? It seems to make sense considering SAA used the bigger (than a 737) Airbus A300/310's and this is a very high capacity route?
What were the reasons / economics that kept the B757 out?
gregdeklerk
Re: Boeing 757 for FACT FAOR route?
Unread post by gregdeklerk » Fri May 03, 2019 9:59 am
I am guessing here till the experts answer, but a 757 is still a narrow body arcraft. Since it is a high capacity route as you say, SAA have a lot of wide bodies on this roue.
Do you not mean the 767? SAA had 3, but they didn't work out. Cant remember the reason.
Millibar
Unread post by Millibar » Fri May 03, 2019 12:43 pm
Hi Greg,
I have it that the 757 is a 'longer' 737, although correctly as you mentioned still a narrow body.
It seems that the 757 would have been a good fit to this route before the larger 737's came to market especially considering the distances and passenger demand?
Trent772B
Closest Airfield: HONG KONG
Been liked: 15 times
Unread post by Trent772B » Fri May 03, 2019 3:45 pm
Probably because SAA had already started taking delivery of the A300 and it therefore made no sense to acquire the 757.
These users liked the author Trent772B for the post:
B727, B747, A320, A330, A340, Alo3, Oryx, King Air, Beech 1900, T6
Has liked: 34 times
Been liked: 88 times
Unread post by GL » Fri May 03, 2019 8:29 pm
Another partial reason is that in terms of the S Curve theory, its better to have a high frequency of flights (using small planes) than a few flights using larger gauge a/c.
The essentials to happiness:
• someone to love,
• something to do,
• something to hope for
Guy Leitch
Stephen Robertson
Been liked: 10 times
Unread post by Stephen Robertson » Fri May 17, 2019 1:09 pm
True, but SAA uses the A319 up to the A340 on this route from time to time. Would it not benefit the company to regulate the amount of flights more efficiently so that these can be kept to a smaller variety of aircraft? It amazed me that SAA never got A321s... for me, if you want fleet commonality then get the A321 for the routes that require more than the A320 but less than the A330... Am I alone in this thought process? Comparing the B752 and A321, they have very similar capacities too...
If you are depressed, you are living in the past.
If you are anxious, you are living in the future.
If you are at peace, you are living in the present.
- Lao Tzu
evanb
Been liked: 35 times
Unread post by evanb » Fri May 17, 2019 2:11 pm
The A321ceo is a poor performer at high altitude airfields due to the undersized wing. At JNB it loses between 10 and 15t of payload which is massive for a narrowbody.
The B752 is significantly bigger than the A321, but also has a much bigger wing and thrust, thus it lifts substantially more, but is a much heavier frame too.
The A330/A340 is run at specific times of day, mostly to link to international connections where frequency isn't as useful, but also where A319/A320 cannot carry the cargo for those connections since it's too small for the A330/A340 cargo containers.
MadMacs
Closest Airfield: GRJ
Has liked: 230 times
Been liked: 38 times
Unread post by MadMacs » Fri May 17, 2019 5:39 pm
The A300's arrived five years before the 757 was built.
When they use the loaded term "denier" that should be the first clue that we're not dealing with a rational opponent in a debate... but "religious" dogma.
Trent772B
Unread post by Trent772B » Fri May 17, 2019 6:29 pm
First A300 (SDB) arrived in 1976. The last (SDI) arrived in 1987.
MadMacs
Unread post by MadMacs » Sat May 18, 2019 12:23 am
ZS-SDA Airbus A300B2K-3C 15 Nov 1976 Blesbok
ZS-SDB Airbus A300B2K-3C 22 Dec 1976 Gemsbok
ZS-SDC Airbus A300B2K-3C 22 Jan 1977 Waterbok
ZS-SDD Airbus A300B2K-3C 15 Feb 1977 Rooibok
Trent772B
Unread post by Trent772B » Sat May 18, 2019 8:23 am
Perhaps I’m relying to much on google.
https://www.airfleets.net/flottecie/Sou ... y-a300.htm
Has liked: 308 times
Been liked: 130 times
Unread post by Ray W » Sat May 18, 2019 9:51 am
Here's a list of the A300's with their histories
These users liked the author Ray W for the post:
MadMacs
MadMacs
Unread post by MadMacs » Sat May 18, 2019 12:27 pm
No problem, I just posted the ones pre 81 with their names :D .
Gandolf
Mags On
Unread post by Gandolf » Sat May 18, 2019 6:33 pm
There was always the rumour that SAA bought the A300 to secure Mirage support and spares for the SAAF.
ERASER
Power off stall
Unread post by ERASER » Mon May 20, 2019 8:12 am
Just a correction on the list Ray, ZS-SDG was a A300C4-203. The only A300 in the SAA fleet that arrived new with a cargo door already installed. SAA used it in the later stages as a freighter.
Rgds
Return to “Airline Chatter”
