vp vs. Oom Piet prop
peterd
Reaching altitude
Has thanked: 14 times
Unread post by peterd »
Hi there
any updates or is the P prop still the best on a 430/400 ?
Just wondering if any new developments on variable pitch props for a jab 3300
Cheers Peterd
peterd
Reaching altitude
Re: vp vs. Oom Piet prop
sorry wrong forum, moved to jab aircraft
Return to “Jabiru Engines”
