vp vs. Oom Piet prop
peterd
Post Take off checks
Unread post by peterd » Wed May 08, 2019 7:54 am
Hi there
any updates or is the P prop still the best on a 430/400 ?
Just wondering if any new developments on variable pitch props for a jab 3300
Cheers Peterd
Flooi
Closest Airfield: FAHG
Has liked: 54 times
Been liked: 20 times
Re: vp vs. Oom Piet prop
Unread post by Flooi » Wed May 08, 2019 11:48 am
Never flew with a vp prop on a Jab, but found the P prop better than 2 g/ad props.
I flew J430 and now J170 with other props an changed to P props... smoother... quieter...
better on performance... easier to repair and much much cheaper... just 2c
Hennie van Zyl
peterd
Unread post by peterd » Wed May 08, 2019 1:07 pm
Hi Flooi
That seems to remain the popular opinion with jab motors.
Thanks
Peter
mikestark
Closest Airfield: FAVG
Has liked: 36 times
Unread post by mikestark » Wed May 08, 2019 3:56 pm
Have not used a P-Prop on a Jab, but did have a ground adjustable 3 blade GA prop on my 450.
In it's lightest configuration (1 on board, limited fuel), I got airborne off 14 as FAIS in 90m after powering against the brakes as long as they would hold. Prop was set for 120 kt cruise so was not pitched for max torque. 3 blade obviously was far smoother than the original lump of wood (std Jab prop) but felt like it was on steroids.
I doubt the P-Prop would be able to match this performance of T/O and cruise, but is certainly a darn side cheaper than ground adjustable or VP, and as a compromise, probably the best value for money.
Mike Stark (Planecrazy)
NEVER Forget - R.I.P. Michel Leusch
http://www.pocketdeal.co.za
http://www.xtremeaccounting.co.za
Flooi
Has liked: 54 times
Unread post by Flooi » Wed May 08, 2019 3:59 pm
Mike. What make of prop is that pls? Sounds good...
Hennie
Hennie van Zyl
mikestark
Has liked: 36 times
Unread post by mikestark » Thu May 09, 2019 5:46 pm
Flooi
It was the GA brand composite prop. I started importing them from the Ukraine. When the war broke out, I could no longer get a response from the guy I was dealing with.
ZuluBen
Unread post by ZuluBen » Mon May 20, 2019 2:07 pm
I have flown with just about every prop available.
Best allrounder and value for money is still Oom Piet's Plank ! 8) :wink:
These users liked the author ZuluBen for the post (total 2):
FlooiBiltong
lessersg
Climbing Out
Closest Airfield: Cape Town
Unread post by lessersg » Sun May 26, 2019 1:33 pm
AX Sport constant Speed-VP, never looked back literally. 3 Blade. Locally Produced. Short field take off and landings awesome, some videos here on avcom showing the performance. :D Motor was fuel injected maybe a bit more power but not at that altitude.
peterd
Unread post by peterd » Sun May 26, 2019 9:23 pm
hi
How many hours have you done with that prop on a jab 3300 ?
vibration and hub cracks was an issue with other vp,s .
Kind regards
Peter
lessersg
Climbing Out
Unread post by lessersg » Mon May 27, 2019 10:32 am
475 hrs on that prop, no issues with Vibration or cracks.
peterd
Unread post by peterd » Tue May 28, 2019 3:45 pm
Sounds great
does the three blade have less load on it ?
and is the diameter less ? i mainly fly off ag sprayer strips in the WC so would be great for less stone pick ups
cap and install cost,also the running cost / hrs till SMOH please :D
Kind regards Peter
lessersg
Climbing Out
Unread post by lessersg » Sat Jul 20, 2019 1:25 pm
Sounds great
Kind regards Peter
Best is to Contact Donald from AX Sport he can assist with all your questions.
