Aircraft Down Nylstroom
Has liked: 685 times
Been liked: 833 times
Re: Aircraft Down Nylstroom
Unread post by jimdavis » Fri May 10, 2019 11:43 pm
So Willie says a Lycoming O-320, and Jvg says a Mazda engine. Which one was it?
Aerodon
Unread post by Aerodon » Fri May 10, 2019 11:48 pm
Unread post by jimdavis » Fri May 10, 2019 11:52 pm
Shows up on Google as Mazda engine
https://www.airteamimages.com/piper-pa- ... 05951.html
Thanks so much Aerodon. I suspect that this might be the bottom line.
FlyingArrow
Radio Call
Been liked: 14 times
Unread post by FlyingArrow » Sat May 11, 2019 6:26 am
Was fitted with Lycoming
These users liked the author FlyingArrow for the post:
Philip Jacobs - Bethlehem
FlyingArrow
Radio Call
Unread post by FlyingArrow » Sat May 11, 2019 6:28 am
Walter105 wrote:
Fri May 10, 2019 8:18 pm
Low level, turning left, maybe into the sun? Thus not seeing the hill?
From the pics of the wreckage I am not convinced of a stall/spin. That looks like it just flew straight into the hill.
I don’t think the sun was a factor. Happened midday.
FlyBabe
Preflighting
Unread post by FlyBabe » Sat May 11, 2019 6:41 am
Maybe a bird strike.
These users liked the author FlyBabe for the post:
Willie
Pete
Has liked: 80 times
Been liked: 51 times
Unread post by Pete » Sat May 11, 2019 7:09 am
Dang this is sad news.. Jan your enthusiasm sense of humour and friendship will be sorely missed.. :cry: :cry:
Chatted to Jan two weeks ago at Vryheid.
A pic of Jan and his O320 Lycoming powered Tomahawk
These users liked the author Pete for the post (total 2):
ACE MANWillie
Avgas
Closest Airfield: FANY Nylstroom
Been liked: 33 times
Unread post by Avgas » Sat May 11, 2019 7:13 am
Lycoming 0 320 engine
Sun was not an issue. It happened at about 1.
Hill is a very low ridge not more than 100 ft high. He ended up about 30 ft from the bottom of the ridge not much more than 500m from runway. If it was engine problems there was plenty space for a landing. Wind was blowing about 10kts from the west straight on the runway with very little turbulence low down. RIP Jan and Engela. Please keep Thinus in your prayers as he saw it happening.
These users liked the author Avgas for the post:
Willie
Balls to the wall
Richard Nicholson
Steve
Closest Airfield: Wings Park
Has liked: 15 times
Been liked: 15 times
Unread post by Steve » Sat May 11, 2019 7:15 am
Possibly pilot incapacitation due to a medical reason like a heart attack perhaps ?
Steve Onions
Iceberg
Has liked: 42 times
Been liked: 118 times
Unread post by Iceberg » Sat May 11, 2019 7:22 am
Sad news. RIP.
Considering his age, I was thinking the same. With good weather, decades of experience etc., an engine failure should have had a better outcome.
The sky is not the limit....
ZS-MDK
Karl Eschberger
Spoke Eagle
Been liked: 25 times
Unread post by Spoke Eagle » Sat May 11, 2019 8:18 am
hi richard, which runway
Funflier
Priming
Closest Airfield: FASD
Unread post by Funflier » Sat May 11, 2019 8:43 am
Another very sad day for the Aviation community... This pic shows he definitely had a Rotary engine before.
These users liked the author Funflier for the post:
Stertsleper
Engine Started
Unread post by Stertsleper » Sat May 11, 2019 8:48 am
Die vliegtuig het n mazda rotary in gehad maar ,oom Jan het gese dit lawaai teveel en toe die Lycoming ingesit.
Volo
Has liked: 104 times
Been liked: 192 times
Unread post by Volo » Sat May 11, 2019 9:07 am
translation required for some herewith below:-
The plane had a mazda rotary but, Uncle Jan said it was too loud and then put the Lycoming in
Unread post by jimdavis » Sat May 11, 2019 9:42 am
Thanks , Stertsleper. :D
