M760 monitoring function
leslloyd
Closest Airfield: brisbane
Has thanked: 2 times
Unread post by leslloyd »
Hi all, my 230 is fitted with an early (s/n 5543) 2004 Microair and it works ok,however when i have 2 channels in the display holding down the
toggle switch (5 secs) only changes the standby channel to the active on top channel. No monitoring function with the "M" dancing from active to standby .Someone has suggested that that early model might not have that function.Can anyone confirm? Should it monitor both channels as the later models do??
colin
jetjr
Re: M760 monitoring function
Unread post by jetjr »
Yes only later n ?? models had dual watch
leslloyd
Well that solves that,Microair hadn't answered my question but had asked me to send it in to them,so i will
just leave it as it is for now as not having a monitoring ability is what i was used to back in the day :wink: of
payed flying.
