May I fly my drone over Town
- 8000 Tousand
- Closest Airfield: FAPE
- Has thanked: 363 times
- Been thanked: 837 times
Re: May I fly my drone over Town
The mods have cleaned up this thread some. Would request that you take a read here before posting any more aggressive responses: https://www.avcom.co.za/phpBB3/viewtopi ... 1&t=227742
- Seven Thousand
- Has thanked: 61 times
- Been thanked: 1056 times
Does your intended use if the drone meet the following definition:Mouser wrote: Thu Feb 27, 2020 6:44 am I am considering buying a drone to take site progress photographs (with the Employer's permission always) after seeing how these are used for planning from an ex SA engineer now in NZ. Some are in urban areas. I probably need to check SA regulations in detail but the small extract giving the 7kg machine weight, if I read it correctly, would seem to allow what I was looking at (Mavic Pro weighing about 1kg) to be flown?
If not, you probably need a RPL and ROC (but probably not an ASL) to operate it.“private operation” means the use of an RPA for an individual’s personal and private purposes where there is no commercial outcome, interest or gain;
- Frequent AvComer
- Closest Airfield: King Shaka
- Has thanked: 1777 times
- Been thanked: 135 times
Thank you for condensing the test. Maybe childish but it is not clear. I would not charge for drone use or the photographs directly but they would be annotated, "printed" (electronically anyway), circulated, used in discussion and to monitor progress. I would absorb the drone costs in my company's fees. Just a tool.heisan wrote: Thu Feb 27, 2020 10:07 amDoes your intended use if the drone meet the following definition:Mouser wrote: Thu Feb 27, 2020 6:44 am I am considering buying a drone to take site progress photographs (with the Employer's permission always) after seeing how these are used for planning from an ex SA engineer now in NZ. Some are in urban areas. I probably need to check SA regulations in detail but the small extract giving the 7kg machine weight, if I read it correctly, would seem to allow what I was looking at (Mavic Pro weighing about 1kg) to be flown?
- Seven Thousand
Eish - you would have to ask a lawyer that - but to me it seems that it is being used to further the aims of your company (therefore not private use).Mouser wrote: Fri Feb 28, 2020 6:08 am Thank you for condensing the test. Maybe childish but it is not clear. I would not charge for drone use or the photographs directly but they would be annotated, "printed" (electronically anyway), circulated, used in discussion and to monitor progress. I would absorb the drone costs in my company's fees. Just a tool.
- Frequent AvComer
- Has thanked: 206 times
- Been thanked: 100 times
Mouser wrote: Fri Feb 28, 2020 6:08 amThank you for condensing the test. Maybe childish but it is not clear. I would not charge for drone use or the photographs directly but they would be annotated, "printed" (electronically anyway), circulated, used in discussion and to monitor progress. I would absorb the drone costs in my company's fees. Just a tool.heisan wrote: Thu Feb 27, 2020 10:07 amDoes your intended use if the drone meet the following definition:Mouser wrote: Thu Feb 27, 2020 6:44 am I am considering buying a drone to take site progress photographs (with the Employer's permission always) after seeing how these are used for planning from an ex SA engineer now in NZ. Some are in urban areas. I probably need to check SA regulations in detail but the small extract giving the 7kg machine weight, if I read it correctly, would seem to allow what I was looking at (Mavic Pro weighing about 1kg) to be flown?
You would be definition of the law need an ROC, which is made up from a number of certs and licenses of which one is an ASL.
- Commercial Drone Pilot and aspiring PPL/CPL (H)
- Professional Photographer
- Freelance Film Producer
- Seven Thousand
Actually, the other way around - the ROC is a requirement for an ASL. But in this case, it will likely be classified as a 'corporate operation' (unclear - whoever amended the Part 93 regs also amended the definition of 'corporate operation', so it is now out of sync with Part 101). For a corporate operation, a ROC is still required, but not an ASL.Shepherd wrote: Fri Feb 28, 2020 8:18 pm You would be definition of the law need an ROC, which is made up from a number of certs and licenses of which one is an ASL.
- Frequent AvComer
Thanks Heisan,heisan wrote: Fri Feb 28, 2020 8:56 pmActually, the other way around - the ROC is a requirement for an ASL. But in this case, it will likely be classified as a 'corporate operation' (unclear - whoever amended the Part 93 regs also amended the definition of 'corporate operation', so it is now out of sync with Part 101). For a corporate operation, a ROC is still required, but not an ASL.Shepherd wrote: Fri Feb 28, 2020 8:18 pm You would be definition of the law need an ROC, which is made up from a number of certs and licenses of which one is an ASL.
I am not familiar with the details of Part 93 and will check it out thank you.
Was not so much trying to define the phases of the process but rather that both of those are essentially needed at the end to operate.
Like all laws, it's the interpretation of the law that matters when arguing a case.
If I read the SACAA materials about the commercial operation versus private (again I am not familiar with Part 93 so I will go and read up about Corporate Operation side of things), the example brought up here would for me appear that it would have a commercial outcome, interest or gain.
Basing that on the below:
For private use –
(a) The RPAS may only be used for an individual's personal and private purposes where there is no commercial outcome, interest or gain;
RPAS Operators Certificate
To initiate the process, the potential operator shall submit a "Letter of intent". Click Forms tab on the right for more to access a form.
Pre-requisites
Commercial Operations:
Air Service License (ASL) issued by the Air Service License Council (which resides at the Department of Transport). Even though ASL is a pre-requisite before issuance of an ROC, both application processes (ASL and ROC) may run concurrently.
Corporate and Non-profit Operations:
Nil
Application process
The Applicant will have to follow the 5 Phase process.
- Seven Thousand
Part 93 is for manned corporate ops. Part 101 has the details for RPAS corporate ops. The problem is that all definitions are in Part 1, and are shared. So when the definition of 'corporate operations' was updated with a Part 93 amendment, it also affects Part 101 (to the point where technically, corporate ops may not be legal at all in Part 101).
- Frequent AvComer
I understand what you mean, thanks for thatheisan wrote: Fri Feb 28, 2020 10:51 pm Part 93 is for manned corporate ops. Part 101 has the details for RPAS corporate ops. The problem is that all definitions are in Part 1, and are shared. So when the definition of 'corporate operations' was updated with a Part 93 amendment, it also affects Part 101 (to the point where technically, corporate ops may not be legal at all in Part 101).
![Dancing \:D/](./images/smilies/eusa_dance.gif)
- Frequent AvComer
Thanks, pretty clearly laid out. I have, on behalf of the Employer, engaged drone surveyors (for myself I was just talking pictures; not surveying) on a number of occasions, only one definitely a fully licenced professional who obtained all the permissions needed. There is a significant commercial market out there, a good number of operators and, for dump or stockpile operations, very economical rather than ground survey. For detail, ground survey every time, maybe in conjunction with a drone.
- Wanna Fly
- Closest Airfield: Orv
- Been thanked: 0
Are you dumb, drones these days barely even cross the kg markRomeo E.T. wrote: Tue Feb 25, 2020 11:29 amAnd what if your 10kg drone crash down vertically from "your" 100m height onto a house/car/people directly below, where is your 50m clear statement now ?Pegasus-Systems wrote: Sun Feb 23, 2020 7:41 pm Does my height of 100m count as 50m away from people?
Also are you not supposed to stay below 40 ft as per the CAA guidlines for using a drone as a "toy" ?
- Frequent AvComer
Ikkd wrote: Sat Aug 14, 2021 9:31 pmAre you dumb, drones these days barely even cross the kg markRomeo E.T. wrote: Tue Feb 25, 2020 11:29 amAnd what if your 10kg drone crash down vertically from "your" 100m height onto a house/car/people directly below, where is your 50m clear statement now ?Pegasus-Systems wrote: Sun Feb 23, 2020 7:41 pm Does my height of 100m count as 50m away from people?
Let me put this as clear as I can…
You are not going to come right here by calling anyone dumb, period!
If you can’t constructively contribute then by all means leave this forum alone.
- Fower Tousand
- Closest Airfield: FASH
- Has thanked: 469 times
- Been thanked: 1103 times
Its a very old thread - but the short answer to the original post was - no.
Do not fly RPA 50m or closer from:
a. Any person or group of persons (like sport fields, road races, stadiums, schools, social events, etc.)
b. Public road
c. Any property without permission from property owner
In a residential area the launch of the drone (even from your own property) would already be within 50m of a public road, unless the owner lives on a small holding.
http://www.caa.co.za/Pages/RPAS/Private ... tions.aspx
b. Public road
Vivere come se mai dovessimo morire
