Sonerai 2L Refurbishment
The Monnet Family Business including Sonerai, Monerai sailplane, Moni motorglider, Monex racer, along with numerous other homebuilt aircraft.
Induna
Closest Airfield: FASD
Has liked: 112 times
Been liked: 131 times
Re: Sonerai 2L Refurbishment
Unread post by Induna » Sat Apr 11, 2020 10:12 am
JvTonder wrote:
Sat Apr 11, 2020 9:59 am
Induna wrote:
Fri Apr 10, 2020 9:02 pm
First engine run after installation. The Rotax is running very smooth...
Lyk baie goed, watse prop het jy daar op?
Wou ook vra, is die VW nie swaarder as die Rotax nie? Indien wel moes die Rotax nie meer vorentoe geskuif wees nie?
Hi Jaco
Dis n Arplast prop.
Die vw is swaarder ja. Daar was n 4kg lood gewig in die stert wat ek uitgehaal het. Dit behoort te kompenseer vir die verskil. Wanneer als klaar is sal ek sien hoe die CG uitwerk met nuwe enjin, cowl ens. Die vliegtuig behoort nou redelik ligter te wees, wat natuurlik n bonus is!
These users liked the author Induna for the post (total 2):
JvTonderHybrydza
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
Induna
Unread post by Induna » Sat Apr 11, 2020 5:57 pm
So today i installed the brakes and also sanded and primed the drop tank. Lookin’ good...
The brakes were not functional at all and i installed new Matco master cylinders. The calipers were reused. They are now working properly.
These users liked the author Induna for the post:
Hybrydza
ZS-WSW | Sonerai 2L
Goose1
Been liked: 106 times
Unread post by Goose1 » Sat Apr 11, 2020 6:21 pm
Were did you get the drop tank or did you build it your self
Hans de Beer
AME A and H
PPL A and H
RV8 ZU-KEA
Induna
Unread post by Induna » Sat Apr 11, 2020 6:59 pm
Hans, I imported it from Titan Aircraft a few years ago.
ZS-WSW | Sonerai 2L
FLYGUYS
Has liked: 30 times
Been liked: 15 times
Unread post by FLYGUYS » Mon Apr 13, 2020 10:28 am
Awesome work Jacques, very inspirational and so good to see an old aerie being given a new life :D :D
Very well done =D> =D> =D>
These users liked the author FLYGUYS for the post:
Induna
ZU-ANG
Induna
Unread post by Induna » Mon Apr 13, 2020 9:26 pm
Today i got the ext tank completed... the paint came out nice and smooth.
Hybrydza
ZS-WSW | Sonerai 2L
Trevor Duane
Has liked: 47 times
Been liked: 79 times
Unread post by Trevor Duane » Tue Apr 14, 2020 7:20 pm
Definitely one of the top 3 refurbs I've seen. Excellent meticulous work. That three blade'r looks fantastic. =D>
These users liked the author Trevor Duane for the post:
Induna
Induna
Unread post by Induna » Tue Apr 14, 2020 8:28 pm
Today i started working on the cowling mods. I will post some pics later, as i want to have more progress before posting pics.
The cowl is taking shape nicely, but looks a bit rough at the moment (as with all cowling mods). I have to make substantial changes to accommodate the Rotax engine.
The cowling will be more streamlined than the standard cowl, taking away a lot of unnecessary drag. The Rotax is much narrower than the VW engine, which allows this improvement.
The lockdown is just restraining my resources as i need some consumables which we cannot currently buy anywhere..
ZS-WSW | Sonerai 2L
Jan
Closest Airfield: COVES
Been liked: 33 times
Unread post by Jan » Tue Apr 14, 2020 9:31 pm
Well done Jacques. Dit lyk na lekker FUN projek :D
These users liked the author Jan for the post:
Induna
Flying is about discipline!
AP325
Induna
Unread post by Induna » Thu Apr 16, 2020 7:17 am
So while I am awaiting to get some consumables to continue with the cowling mod, I installed some stainless steel heel plates on the floor panels. They are very smooth and allows ones feet slide to easily.
Hybrydza
ZS-WSW | Sonerai 2L
Induna
Unread post by Induna » Sat May 02, 2020 7:59 pm
Hi. I got plenty done and is now happy to share some pics of the progress.
I used the old cowl as a starting point and modified it to fit around the engine. The Rotax allowed me to narrow down the cowl quite a bit, which will reduce drag.
I wanted to do something different, to have some of the old Sonerai looks but add some new flavour.. so the plug i made have a bit of the Sonerai but also a more modern “turbine” look...
So here i cut the old cowl
Hybrydza
ZS-WSW | Sonerai 2L
Induna
Unread post by Induna » Sat May 02, 2020 8:01 pm
Then i added some foam to enable me to sand the shape that i want...
Hybrydza
ZS-WSW | Sonerai 2L
Induna
Unread post by Induna » Sat May 02, 2020 8:03 pm
I added some filler and more elbow grease...
Hybrydza
ZS-WSW | Sonerai 2L
Induna
Unread post by Induna » Sat May 02, 2020 8:05 pm
And then more filler and sanding :lol:
These users liked the author Induna for the post (total 3):
heisanHybrydzaKevin McCormack
ZS-WSW | Sonerai 2L
Has liked: 267 times
Been liked: 293 times
Unread post by V5 - LEO » Sun May 03, 2020 9:05 am
....WOW!!
Return to “Sonex”
