ZSPYS Cessna T210R S/N 210-64969
An informal register and background to South African aircraft. Please take the time to read the 'Before you post', or your entry could be deleted.
HKraatz
Closest Airfield: EDFM
Has thanked: 1 time
Been thanked: 1 time
Unread post by HKraatz »
Hello fellow aviators! We have recently bought a Cessna T210R (S/N 210-64969) which used to be ZS-PYS until +- 2 years ago. We have complete logs and documentation since when the aircraft got imported to SA in 2007; first AMO which took care of import from a technical perspective was HELI-FIX as far as I understand.
Unfortunately we have no logs and documentation at all from its‘ time on the US register... does anybody know that aircraft and has ideas on how to try to obtain logs? I assume logs where available when imported to SA
Thanks indeed and all the best these crazy days!! Hanno
lampiesJR
Closest Airfield: Porterville
Has thanked: 36 times
Been thanked: 164 times
Re: ZSPYS Cessna T210R S/N 210-64969
Unread post by lampiesJR »
Hanno probeer kontak maak met die FAA se regestrasie afdeling. Hulle kan jou n CD gee met al die dokumentasie wat hulle het. Gewoonlik baie behulpsaam
NC Lambrechts
ZU-CUB
ZS-THX
Phil 4:13
Return to “Our Register”
